-   -   How many 911 3.6 conversions out there ? (http://forums.pelicanparts.com/porsche-911-technical-forum/238501-how-many-911-3-6-conversions-out-there.html)
ted 01-04-2018 06:20 AM
Awesome rides on this thread! :):)
Update our 3.6 Conversion going on 12+ years with many track events and street miles just freshened it for the second time, new bearings and springs.
Had to replace the original fuel harness, evidently the factory low voltage wires that go to the injectors was a factory recall item.
Check your stock 3.6 fuel harness for brittle or broken wire insulation.
Rowing the 3.6.
https://youtu.be/YLB4hvzhM-g
http://forums.pelicanparts.com/uploa...1515078164.jpghttp://forums.pelicanparts.com/uploa...1515078209.jpg
build thread.
http://forums.pelicanparts.com/porsche-911-technical-forum/207216-mirage-911-rsr-project-pics-18.html
Thanks to Mirage http://www.mirageintl.com/ for the 3.6 conversion and car build.
Vic Ofner Along For The Ride: Porsche 944 GTR 003 / Time with...Vic Ofner for the engine builds and recent restoration.
G50911 01-04-2018 07:37 AM
Originally Posted by -Levi- (Post 9483212)
here is a short video of mine
slow progress- but progress https://www.youtube.com/watch?v=5uRlhb68__U
GT3 exhaust?
cliyde 02-23-2022 09:01 AM
Yep, "under-cover" 92' 3.6L in the G body. Fun doesn't even begin to describe it!
https://i.postimg.cc/W13QmkrQ/2017-03-20-17-33-19.jpg
https://i.postimg.cc/CKnXXpc7/2164965.jpg
aston@ultrasw.c 02-23-2022 09:51 AM
1993 3.6, G50
http://forums.pelicanparts.com/uploa...1645642024.jpg
http://forums.pelicanparts.com/uploa...1645642224.jpg
plexiform 02-23-2022 12:35 PM
1975 911S
92 964 3.6L
http://forums.pelicanparts.com/uploa...1645650822.jpg
msmall215 02-23-2022 01:33 PM
'84 C3.2 chassis, '92 964 3.6 on Jenveys/Motec, and an '82 915 with the usual enhancements
https://live.staticflickr.com/65535/...cdbcfd4d_c.jpg
https://live.staticflickr.com/65535/...2cb846f4_c.jpg
arrivederci 02-24-2022 07:07 PM
Well I'm sub'd but don't think I ever posted. Mostly done by me personally with a thread about the build. Now at a great local shop adding a Retro A/C system so I'll drive it more through the summer.
http://forums.pelicanparts.com/uploa...1645761884.jpg
http://forums.pelicanparts.com/uploa...1645761976.JPG
Joe Bob 02-24-2022 11:57 PM
How much did the ITB upgrade run you? Have you done a before and after Dyno or did you just rely on your seat of the pants impression?
Hulley 02-25-2022 03:13 AM
Link to your thread? I have pics of this car saved, very beautiful, found it on RetroMod.
msmall215 02-25-2022 04:54 AM
Built the motor with ITBs before it went in the car it, so no before and after, but it scoots. Previously I had an SC that I swapped from CIS to ITBs and it was a noticeable difference. No dyno runs with the CIS, but with the ITBs, it put down 200hp/189tq at the wheels and was internally stock, so they certainly make a difference, but to unlock the full potential, you're going down the rabbit hole of pistons and cams at the very least.
arrivederci 02-25-2022 01:52 PM
http://forums.pelicanparts.com/porsche-911-technical-forum/643329-72-rust-repair-long-overdue-update.html
SalazarS2K 03-09-2022 08:22 PM
For those with a 964 conversion, can someone please tell me of your coil packs hook up to both distributors on the motor? Apparently o only have one wire hooked up and there isn’t an attachment from the distributor to the second coil pack. Thanks.
kd126500 03-10-2022 09:15 AM
71 911 3.6
Finishing mine. 95 3.6 with PMO carbs, 915 gearbox, dual out center GT3 style exhausthttp://forums.pelicanparts.com/uploa...1646935955.jpg
flyn-hawn 06-18-2022 10:48 PM
1975 964 3.8
http://forums.pelicanparts.com/uploa...1655621241.jpg
BoxsterGT 06-23-2022 05:30 AM
Factory Level Fuel Lines for 3.6 Conversions
For those of you also considering a 3.6 swap, here is a FYI-
Many of these conversions are using aftermarket Lines & Hoses of the AN type.
Unknown to many, some of these AN type Hoses are actually made in China. The best way to tell is to peel back the SS Braid. The mfg info MUST be printed on the hose. If not there, this is an inferior Chinese product.
I thought I would show what can be done using Porsche approved German E-85 Rated Metric Hose & Fittings.....
http://forums.pelicanparts.com/uploa...1655988625.jpg
http://forums.pelicanparts.com/uploa...1655988717.JPG
http://forums.pelicanparts.com/uploa...1655989792.jpg
This is the best E-85 Rated Hose available, and with a SS braid, and yes, made in Germany.
And when a custom fitting is needed and we cannot buy them from Germany, we have them machined locally.....
http://forums.pelicanparts.com/uploa...1655990098.JPG
http://forums.pelicanparts.com/uploa...1655990376.JPG
http://forums.pelicanparts.com/uploa...1655990457.JPG
http://forums.pelicanparts.com/uploa...1655990720.JPG
For info, please email me. I do not accept pm's as I cannot send photos via pm.
len.cummings @ verizon.net
3rd_gear_Ted 06-23-2022 07:26 AM
On the west coast
Here is a good supplier and metric AN hose fab person.
22MM ID AN style front oil lines were provided for my 3.6 conversion
https://www.facebook.com/TorinoMotorRacing/
rswannabe 11-28-2022 09:26 AM
‘74 911 with steel widebody, ‘91 3.6 with PMO itb’s and 915/67 with euro cooler and lsd.
http://forums.pelicanparts.com/uploa...1669659919.jpg
Darryl Irvine 07-18-2025 08:39 AM
my 3.6 conversion
1982 sc, with 1995 non-vario 3.6, custom exhaust. http://forums.pelicanparts.com/uploa...1752856751.PNG
http://forums.pelicanparts.com/uploa...1752856751.jpg
Darryl Irvine 07-18-2025 08:41 AM
http://forums.pelicanparts.com/uploa...1752856895.jpg
http://forums.pelicanparts.com/uploa...1752856895.JPG
3rd_gear_Ted 07-18-2025 10:21 AM
http://forums.pelicanparts.com/uploa...1752862655.jpg
Conversion done in 2015 with an Instant G motor and a top end rebuild.
Short gear 915 with a Wevo.
Time trial & W2W racing for 10 years.
Now back to the street with an Oslo Blue paint job.
chucksmith 07-18-2025 04:43 PM
80SC widebody, 3.6VRAM with 915, full Griffiths AC set up
http://forums.pelicanparts.com/uploa...1752885777.jpg
http://forums.pelicanparts.com/uploa...1752885821.jpg
Ryan_Cunningham 07-19-2025 07:02 AM
Originally Posted by chucksmith (Post 12500150)
Looks great.
This thread is killing me. We started my 3.6 swap Wednesday, but when installing the LSD we made the decision to do a bit of work on the transmission which we won’t get back until Tuesday.
http://forums.pelicanparts.com/uploa...1752937299.jpg
Bill Verburg 07-19-2025 10:00 AM
Originally Posted by Ryan_Cunningham (Post 12500376)
Looks great.
Just a heads up, I see that you are using the 993-engine mount cross bar, console and tin. This requires a 3/4 spacer which will drop the rear of the engine and lead to issues w/ exhaust appearance and ground clearance.
I'd highly recommend using a 3.3 console, regular 911 or RSR type 911 cross bar and Sheriden 3.6 conversion f/g to replace the tin. You do need to use a single or double sheave crank pully as well.
W/ the 3.2 parrts the engine and exhaust sit exactly as in any other 911.
http://forums.pelicanparts.com/uploa...1752947838.JPG
http://forums.pelicanparts.com/uploa...1752947985.JPG
Ryan_Cunningham 07-19-2025 10:52 AM
Thank you for the guidance Bill. I was aware I'd have to lower the engine by about 25mm. I purchased the PMS 3.6 conversion to early 911 tin, that is what we installed yesterday. That won't work?
I have a spare RSR crossmember sitting in my garage and we have the single pulley conversion waiting installation once we get the front and aft pulley adapter. Timmons told me the RSR crossmember wouldn't work when I ordered the kit from him.
Do you think this exhaust will have clearance issues?
https://werksperformance.com/products/copy-of-porsche-993-carrera-rsr-header-muffler-kit-with-heat-dual-inlet-outlet-muffler-copy-of-993-rsrwh
I'm also starting to have concerns regarding the 915 being able to handle 285-300 rwhp despite us fixing any issues with the transmission. I'm not going to hammer on it, but with and OS Giken LSD and rebuilt 915 it should be fine for several years without service...? What are your thoughts Bill?
arrivederci 07-19-2025 03:06 PM
On the subject of engine mounts, notice that the one in Bill's picture is reinforced at the ends. This is a great idea...those things twist quite a bit.
For transmission durability, I guess it depends how you treat it. I too heard people cautioning me about the 915 but I haven't had an issue nor do I know anyone with a 3.6L that has grenaded their 915. I did go with an '84 euro 915 (not my stock magnesium cased one) and I didn't add an LSD hoping to stress the transmission a little less, maybe having a little wheelspin here or there on one wheel. 911s get such great traction anyhow and I don't track this car, so the lack of LSD is hardly noticeable.
Bill Verburg 07-19-2025 03:14 PM
The 993 console, crossbar and modified tin work but force the rear of the engine down over 1 1/4" due to the height of the tin
http://forums.pelicanparts.com/uploa...1752966489.JPG
the 3.2 parts w/ Sheriden f/g tin replacement fits like a glove and returns the engine to it's usual position
http://forums.pelicanparts.com/uploa...1752966626.JPG
That exhaust looks exactly like the one I bought from Fabspeed, and I do mean exactly. If so it's great, best I've ever heard including the ones I've used on my 993.
Only nit is that the tips are a little weal, appearance wise
http://forums.pelicanparts.com/uploa...1752966794.JPG
Duc Hunter 07-20-2025 01:41 PM
1975 911S steel wide body, front fenders 1” wider each than 930 fenders, 915 gear box, 1993 964 3.6, Rothsport headers with GT3 muffler a-la Guntherwerks….. just finishing rust repair and paint after driving her as a black and white rat rod for 10 years. Build thread coming soon???
how it started in 2016...
http://forums.pelicanparts.com/uploa...1753047246.JPG
How it was going (DRT2022)....
http://forums.pelicanparts.com/uploa...1753047246.jpg
Almost back on the road now....
ToySnakePMC 07-21-2025 06:52 AM
Love the blue finish & chrome trim. Good job!!
Patrick
Duc Hunter 07-21-2025 02:02 PM
Patrick
Thank you kind sir.
jimtweet 07-21-2025 05:43 PM
http://forums.pelicanparts.com/uploa...1753148528.jpg
AlBackus36 07-22-2025 05:41 AM
Bill,
I have a timmons'/IG style 3.6VR swap in an '87. It is freaking tight on the top.
Have you fit a 3.6 varioram with the 3.3 console, 3.2 bar, and sheridan tin? I'm not actually sure the engine could go up another inch with the ICV already pressed against the insulation.
I know you're familiar and will echo that if you do nothing, your exhaust will be lower than normal. I scrape when driving hard and have a passenger in the car. I'm pretty low though.
Another observation: There is some slight angularity at the transmission mount, but it's in the opposite direction you'd expect. It is tilted with the forward end down, indicating the engine is actually higher than the trans... I'll see if I can snap a pictures of this. Maybe my memory is off because this would be unusual.
I'm fascinated by this swap now. It feels like it's not quite fully understood.
https://imgur.com/a/sS7lGTN
PS: Not sure if photo is working as imgur is blocked at work. The little spouts are header dumps. One is unfortunately aimed a little downward.
chucksmith 07-22-2025 06:15 AM
this is how my exhaust sits with my Timmons VRAM set up . It is tucked in nicely, it is a tight fit at the top of the VRAM intake though.
http://forums.pelicanparts.com/uploa...1753193729.jpg
chucksmith 07-22-2025 06:17 AM
http://forums.pelicanparts.com/uploa...1753193843.jpg
AlBackus36 07-22-2025 06:46 AM
Thanks for the extra pics, Chuck.
I want to clarify the car is more than drivable. Ryan, don't think it won't be usable. I drive the car hard and it doesn't get in the way. If I have someone in shotgun I have to be extra careful over speed bumps or driveways. That's mostly it.
Ryan_Cunningham 07-22-2025 07:44 AM
Awesome. The exhaust I posted was actually old - It is the Fabspeed RSR. The owner apologized and gave me $1,000 off. Still a pricey piece of kit but sounds amazing from the clips I've heard.
Racerbvd 07-22-2025 07:58 AM
How cool would it be to have one of these in a G Bobby? http://forums.pelicanparts.com/uploa...1753199850.jpg
AlBackus36 07-22-2025 08:20 AM
Good, I just didn't want to spook you away from your current path. There are hundreds of cars out there that have been done with the 3.6 console, etc.
I'm convinced the Varioram guys can't go higher, but would love to be proved wrong so I can raise my exhaust :)
Bill Verburg 07-22-2025 03:15 PM
You'll either need to make room at the top or fab custom I/O pipes at the bottom
Take your pick
Duc Hunter 07-22-2025 03:48 PM
Take your pick
First wont you need to hit the lottery? I know a Rothsport 3.6 that makes 100HP/liter is at least $40k....plus your running engine. Byron's engine....double that for normal people? I'm out. LOL
plexiform 07-22-2025 09:20 PM
Any color is fine as long as it’s black/black. :D
Good to see so many fellow nutjobs who have spent a lifetime and small (sometimes not so small) fortune putting together their own personal versions of pure 3.6L German automotive bliss. Has been a fun and sometimes challenging 12 years for me. But this one is finally a masterpiece IMHO. Is the finished product everything I’d hoped it would be…yes. Would I do it again….no. My advice to anyone about to start down this path: if you’re not a mechanic and will be outsourcing the work, just buy a completed project and pay the premium for a properly sorted example.
75 911S
Steel 930 fenders
5spd 915 transmission w/ wavetrack LSD
93 964 3.6L motor with Rasant Products GT3 intake w/ stock internals
Motec engine management
REVV short shifter
Raised shift tunnel by Rebel Racing
North Hollywood Speedo gauges with LED lighting
Getty Design clear carbon hood
Rennline carbon hood and decklid 356 style struts
Fikse Fuchs (like the first Singer models) 17x9/11
Nitto 315/235
Sport comfort seats refinished in perforated leather
Roll cage (ready for the track but never been to the track)
Fiberglass rear early Turbo decklid
Rebel Racing brembo adapters for big red brake kit from 996
Rebel racing adapters for Bilstein coil overs
Rebel Racing 917 style aluminum accelerator pedal
Rebel Racing semi solid engine mounts
Custom suede headliner
Leather covered RS style door cards and all dash parts
New red seat belts
Customs keys by Formawerx
Cibie rally lights
Bosch fog lights
LED bulbs in the H4 headlights.
Rasant Products rear tail lights (LED),
Rasant Products brushed aluminum dash
Stereo delete
Carbon fiber RS style heat duct
Momo 6c prototipo steering wheel
Billy Boat exhaust with heat exchangers
A/C delete
Windshield wiper fluid pump delete but wipers work
Wet weight 2499 pounds
RWHP 301 on the dyno
http://forums.pelicanparts.com/uploa...1753245425.jpg
