project 911's Avatar
Not to hijack this, but is there a way to bench test a tach to see if it is functional? I installed an MSD and the tach has never worked since. I tried a tach adapter last night with no luck and now I just wonder if I fried the tach during my install.
Steve B.
1971 T 2.2 w/Zeniths
Gruppe B member 171
Mid 9 Web Site Guy
Old 09-02-2005, 05:04 AM
Lorenfb's Avatar
"but is there a way to bench test a tach to see if it is functional?" - project 911 -
Tachs are triggered either by a negative or positive pulse from the ignition unit.
As an example, the early Porsche tachs (not SC with a 6 pin CDI) are triggered
by a positive pulse. The SC type tach is triggered by a negative pulse.
So, the beat approach is to use a pulse generator after the tach is powered with
+12 & grd. When a generator is not available, a momentary switch connected
to either +12V or ground & the tach input can simulate a pulse generator if used
rapidly. A coarse file connected to + 12V or ground & a lead connected to the
tach input & rubbed against the file will simulate pulses and result in needle
movement.
Note: Some older tachs require a high voltage pulse from the ignition coil
and can't be tested as described above.
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 09-02-2005, 05:49 AM
Thanks Loren,
I think I'll try that before pulling any more hair out.
Steve B.
Gruppe B member 171
Mid 9 Web Site Guy
Old 09-02-2005, 05:55 AM
