steering issues need help???
Hope some one can help, sitting in the drivers seat I can now move the steering column up and down about an inch, the car still steers perfect what could have broke?
79 sc
Old 09-05-2005, 03:40 PM
kqw kqw is offline
Yea, simple 10 minute fix.
It's probably the sleeve that slides over the steering column shaft.
Remove the steering wheel and you'll see where that sleeve fits. It's probably worn or has broken into pieces. Order a new sleeve, I recommend the newer edition, metal and slightly longer.
About $12.00.....
cheers
The Fox
Carrera
Old 09-05-2005, 03:55 PM
Barrpete's Avatar
It's probably the plastic bushing at the top of the steering shaft. Had the same problem about 2 months ago. The good news is that it's an easy and inexpensive fix. You can buy a metal replacement bushing from our host for about $6. Takes about 20 minutes to replace. Do a search and you'll find there's several threads on the topic.
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
1955 Chevy Apache 3100 Pickup
"A little knowledge is a dangerous thing"
Old 09-05-2005, 04:00 PM
