Question Shifter alignment: In middle of fixing..Help needed
Right now I'm into the shifter that went limp fix. As suggested it appears to be the shifter shaft turning in the cylinder at it's base.
In an earlier thread one mentioned that the shaft is epoxied into the cylinder. Should I replicate what the factory did with J&B or MIG weld together permanently? Will welding come back to haunt me if I'm back in here for an upgrade or other project?
Also, should the two tabs align perfectly parallel to each other when I reattach?
Both shifter bushings get replaced while I'm in here.....
TIA for any help.
Warren & Ron, may you rest in Peace.
Old 09-05-2005, 11:02 AM
Bumparoo
Old 09-05-2005, 01:54 PM
Rick,
Yes, they're epoxied together from the factory; I'm guessing so the tabs are parallel during final assembly.
I would suggest lining up the shift lever, then apply alignment marks on both pieces before welding.
Here's some additional info you might find interesting.
Sherwood
Old 09-05-2005, 02:04 PM
lateapex911's Avatar
[Non engineer mode ON]
I can't remember, but is the housing and tab assembly alloy or steel?
For some reason I am thinking alloy, but it makes more snse for them to be steel..
In the event it is alloy, be very careful rebending the tabs to paralell, lest they fatigue and fail, eithr now or later.
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 09-05-2005, 02:11 PM
Thank you, Sherwood. Just what I needed. I'm thinking I can put a tack or two with the shifter assembled (out of the car) and everything protected with a fireproof cloth.
Old 09-05-2005, 02:12 PM
Tabs don't need to be bent. Merely aligned as the shifter shaft is positioned within the cylinder it sits in.
Old 09-05-2005, 02:13 PM
One more question.
Even though I took pics and documented the procedure I'm stuck on the alignment of the ball cup receptacle...for lack of a better term.
I marked the shifter rod and the receptacle so I could line up accurately upom reassembly. Now that I've lined it up and tightened it's cock-eyed. Should it be parallel to the floor?
Here you can see the the shift rod bracket is parallel but the recepticle is off a few clicks to the right.
Old 09-05-2005, 04:01 PM
Rick,
Should be okay, but there's a shift tube adjustment at the shift coupler attachment. If shifting is not giving you any problems (other than the dangling shift lever), I'd think twice about "fixing" it.
However, if you want to:
Loosen the shift coupler clamp and rotate the shift tube CC so the ball cup receptacle is vertical, then tighten the clamp. This may or may not throw off the adjustment which I assume is fine now.
Sherwood
PS: Don't forget to mark the tube and coupler so you can reference your adjustments
Old 09-05-2005, 04:13 PM
Sherwood, Since it was fine before I'll leave as is and assemble enough to make a determination. If it's messed up I'll do the adjustment at the coupler as you suggest.
I thought I'd have time to do the brass coupler replacements but I've been taken my time today. Those will have to wait.
After this round your system goes in
Thanks again for your sharing your expertise.
Old 09-05-2005, 04:40 PM
OK
Seems the shift rod was in gear so it was held in a cock-eyed position. As I reassembled it straightened right out.
The ride into work this morn was real nice. Nice crisp shifting. Next week the couplers go in. Actually I'm kind of glad I didn't do them yesterday. Now I'll be able to make a before and after comparison.
Thanks for your help Sherwood.
BTW, I'll post pics of the process. I tried a few techniques for removing and replacing the shift rod bushing. I'll post what I found to be the easiest.
Old 09-06-2005, 06:22 AM
Virginia Rocks!
VaSteve's Avatar
Originally posted by RickM
OK
The right into work this morn was real nice. Nice crisp shifting. Next week the couplers go in. Actually I'm kind of glad I didn't do them yesterday. Now I'll be able to make a before and after comparison.
Amazing what a difference that makes!
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 09-06-2005, 03:31 PM
