Question on front shock replacement
I am replacing the front shocks on a 74 Carrera with Koni Classics inserts. The instructions say to put 50ml of oil in the strut housing. What type and weight of oil is recommended.
abit off center
I used a mixture of antifreeze and regular motor oil, there should be some in there already..
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
I've used ATF. It's to help the heat transfer from the insert to strut body.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
I used motorcycle fork oil.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
