ATE 23mm MC install question
Am I correct in presuming that I will need to fabricate 90 degree bend brake-fluid-from- reservoir-feed-line for front port of ATE 23mm master cylinder when installing on 77 911? There may be a better way but I don't know what it is. Also - Is the pedal rod throw the same as used with the standard 19MM MC? Thanks. EPS - Indianapolis
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. - |
There is an "S" bent piece that comes in a kit if you don't want to make one, but you do need. The pedal rod needs to be longer, I think it's 10mm's. A stock one won't work. The longer rod is also included in the kit. I think the kit is available from VCI and Smart Racing to name a few.
Harold '79 930/DP935 (sold) '68 VW 3.3 Turbo Crewcab |
i never heard of it being used on 77 and up with power brakes.
