Alternator Rebuilder or High-Amp New Unit
My alternator is not dead yet! 12.4-12.75v at 2-3K rpm! I will be thinking about just replacing the regulator, but...
to be on the safe side, I am open to everything being 'kinda' new. So, does anyone recommend a reputable rebuilder in the Ventura/LA County areas? Thanks. Also, has anyone bought and used the new high-amp alternators our sponsor carries? |
does the high amp have larger dia windings?
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
I do not know the specs. I just thought it would be an upgrade if I were to buy a new one.
Any armature place can rebuild it. THey are not that complicated. I would take it off yourself and install it yourself.
Cab: Call Foreign Alternator and Starter in Northridge. I had mine rebuilt there two years ago for $75. It's a hole in the wall shop, but the guy knew what he was doing and, so far, it's been working perfectly.
818 772-1700 (near the corner of Reseda and Parthenia, IIRC.)
1984 Targa |
Local autoparts stores can get rebuilt ones. Autolite supplies rebuilt Bosch units for around a hundred bucks.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
