Porsche-pa
75Carrera's Avatar
Help Understanding Motronic
I've been watching the threads about the 3.2 Motronics.
Since my recent motor install the tach has been acting up (sticking or just falling to zero) and has now stopped altogether.
I saw several possibilites in the threads but so far haven't found it. It's not a loose connection (at least not at the tach) and my battery is brand new.
It sounds like other things in the electrical system can affect tachs. Is that true?
Could it be something as simple as the voltage regulator? I thought it might be the tach itself and I suppose it still could be. Any ideas on the best way to chase this problem down without spending a bunch to have someone else do it?
Current Garage:'04 996TT S Cabriolet, 1975 911 Carrera 3.2 powered (my Precious),
Also rans...
'02 996TT, '03 996TT, 1967 912, 95 993 C2 Cabriolet, 76 911S Carrera, 2014 Carrera S, 2014 Turbo S, 1999 AMG SL, 1966 Lotus 7,
Donny
Old 09-18-2005, 01:23 PM
Early_S_Man's Avatar
Porsche Crest
Donny,
Monitor your system Voltage while driving ...
If it is outside the nominal range of 13.2 - 14.5 Volts, then tachs can behave in various st range ways.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 09-18-2005, 03:25 PM
Porsche-pa
75Carrera's Avatar
Thanks Warren,
You have been a very helpful member.
Without a gauge to monitor how do you check it?
Also rans...
Donny
Old 09-18-2005, 03:33 PM
Detached Member
Hugh R's Avatar
Some auto stores carry digital voltmeters that plug in the lighter.
Hugh
Old 09-18-2005, 03:59 PM
Porsche Crest
Donny,
It doesn't have to be done with a permanently-mounted gauge.
Analog or digital multimeter can be used with dedicated special test cord going from banana plugs to 12 Volt accessory plug, as in the pic below.
Warren Hall, Jr.
Old 09-18-2005, 04:12 PM
Porsche-pa
75Carrera's Avatar
Just what I needed to know. Thanks guys!
Also rans...
Donny
Old 09-18-2005, 04:19 PM
