Is it worth parting out a MFI 72E motor
Anybody have any experience parting a motor?
Is it worth it or just a hassle ? and is a 72E motor worth parting out or selling as a whole.
This would be to offset a 3.6 or 3.2 swap.
The motor runs really pretty good , I put brand new SSI's and silencer , has all the MFI in great condition( runs a little rich though might just need adjusting never looked into it) , good oil pressure, oil cooler leaks bad,
Is a E case worth anything for the #'s .
E cams ? Can these work in a 3.0?
Any thoughts
Old 09-14-2005, 08:47 PM
Is there any parts off a E motor that are worth something besides the MFI stuff and
SSI heat exchangers.
What would be a fair price for almost new SSI heat exchangers?
Old 09-15-2005, 07:33 AM
billwagnon's Avatar
maybe 80% of new price on the SSIs? It would be a deal for someone.
I would think you're better off selling the whole motor, running, than parting out. if I was building a motor and needed cams or whatever, I would buy new to avoid other potential problems. But that's just me.
Old 09-15-2005, 07:40 AM
Friend of Warren
Why not just sell the complete engine? Less hassle and you should get just as much money as you would parting it out.
Kurt V
Old 09-15-2005, 07:41 AM
Thanks for youre input on this
80% off new price wow I was thinking like 50% max 60% off new price.
I guess the only reason Im thinking of parting it is I dont see too many people interested in a motor that is pretty leaky. It would definitely need to be resealed so I think that really kills the value.
So what would a leaky E motor be worth to someone?
again thanks.
Old 09-15-2005, 07:53 AM
Gon fix it with me hammer
svandamme's Avatar
don't know the history of your engine , but when i took my 73 apart for the rebuild , there was almost nothing in it that was reusable
the crank shaft was the only thing that didn't need refurbishing ( other than polishing ) oh , and the oil pump and gears
had to refurbish the crankcase, the rods, the heads
and toss away the P&C's the valves , the springs the camshafts and the rockers , tensioners and so on...
i still have the camshafts laying around , but the value is next to nothing since they need welding and grinding , the shipping cost to camgrinder in the US is more than they're worth.
you could part it out and throw things on ebay , but my experience is people don't bid on worn out things if you advertise them that way, and if you don't , it's fraud
a full engine however they will bid on , since they all hope it might still be good on the inside , even if you just say , pulled from car in running condition , no warranties on the internals whatsoever...
Stijn Vandamme
BIMDIESELBMW116D2019
Old 09-15-2005, 08:13 AM
Warren Hall Student
Bobboloo's Avatar
To get the most money from the motor. First run a compression test. Then sell the longblock. Then sell the MFI, SSIs, and other perifery seperate. i.e. fan, shroud, dizzy, cooler.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 09-15-2005, 09:56 AM
skinnerd's Avatar
If it was me....I would want to buy it as a package, and rebuild it to RS specs. So I'd want the SSI's, MFI, and all the rest on it. I simply wouldn't be interested in that engine missing all that stuff.
If your engine is fairly tired as it sounds....it is likely worth $1500-2000 max I would guess. That is all I would pay....about $1500 total.
There is just so much money involved in rebuilding a 911 engine, that it's not worth needing the work.
My 2 cents....
With that said, how much were you hoping to get for the entire engine package???
Any pictures of the engine?
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 09-15-2005, 12:23 PM
zotman72's Avatar
This is Grady here. I'm at Bill's house. We just got his PCA
Club Racer running for the DE tomorrow and the Club Race at Pueblo this weekend.
I'll buy it the E engine, do a complete rehab and we can use it for MFI seminars. That will let me stage all sorts of cleaver malfunctions. This will force me to buy a new engine dyno.
E-mail me.
Best,
Grady
gradyclay@hotmail.com
Bill
'72 911T-2.4S MFI Vintage Racer(heart out), '80 911SC Weissach,'95.5 S6 Avant Wunderwagen & 2005 997 C2S new ride.
Old 09-15-2005, 03:23 PM
Put me next in line behind Grady. I'm looking for a '72 E engine.
Mike B.
'72 911E Coupe
Early "S" #1065
Old 09-15-2005, 03:56 PM
skinnerd's Avatar
Once this one is gone, there is also one on Ebay right now...
Doug
Old 09-15-2005, 04:01 PM
I am thrid inline to buy it, it would be prefect for my 72
Derek Oxford PCA - Nationally Certified Instructor
2002 Boxster S ( race car)
2010 LR4 2009 GMC Sierra (Porsche Support
2011 M3 4Door
Old 09-15-2005, 04:10 PM
Grady Clay's Avatar
I’m home.
Guys, remember I want an almost worn out everything to use as a mule so I can demo various malfunctions, mal-adjustment, and extreme wear. Most (sensible) people want a rebuildable engine. Stijn had a classic example that probably was too expensive to rebuild.
I would make it where it has continuously jumping pump timing, three bad nozzles (all on one side), a cam out of time, a valve with negative clearance, the cold start dribbling, throttles out of correlation, the thermostat stuck on, the mixture adjusted to compensate and a 911T MFI pump. That will actually run but demonstrate all sorts of interesting symptoms. Now, lead a group through a CMA session with it and bring it back from the dead.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 09-15-2005, 05:51 PM
billwagnon's Avatar
oh no you have an extra "f" in there that changes everything. when I buy SSIs I would go with used if I knew I could save 20%. Or 30%. So you would be able to sell (hypothetically to a person in my position) for 70-80% of what new ones cost. SSIs don't go bad, do they?
Old 09-16-2005, 08:11 AM
Senior Member
May be another '72 MFI engine coming available here in the Phoenix area if someone is interested.
JoeA
Old 09-16-2005, 08:26 AM
What?!?!
DonDavis's Avatar
running shoes, couple tools, fishing pole
1996 Subaru Legacy Outback AWD, 5speed
2002 Subaru Impreza WRX, 5speed
2014 Tundra SR5, 4x4
1964 Land Rover SII A 109 - sold this albatross
Old 09-16-2005, 09:32 AM
Again, thanks guys for helping me out.
I have been swamped with work lately thats why I have been slow to respond.
Bill - my bad, thats what I understood I dont know why I threw in that extra "f''.
I would be really happy if I could get 70-80% of what new ones are going for.
svandamme- What was youre engine running like before you tore it apart?
Was this the S motor?
My E motor is still very strong with no funky noises, valves are still pretty quiet also with good oil pressure, just leaky, okay very leaky.
Old 09-17-2005, 08:21 PM
Herman-
Did you get my email? Also sent PM.
Mike
Mike B.
'72 911E Coupe
Early "S" #1065
Old 09-17-2005, 08:26 PM
Grady- Right now the motor is still in the car and I think is still very strong, for 165hp anyway. On a nice hard packed dirt road it still has the hp to power slide the rear, still very fun.
but right now im a little all over the map, im not sure what im going to do with the motor.
Im leaving sunday for work and I will be away for 4-8 weeks, whatever I decide it will have to wait till I get back. Im considering parting it out like Bobboloo suggested, but Im still unsure what im going to do. If you want PM me if you want me to let you know when I get the motor out when I get back.
Thanks again and I will try to tune in now and then with more of my boring questions.
Old 09-17-2005, 08:43 PM
Originally posted by real550A
Herman-
Mike
Hey Mike
I just read your PM, check youre PM in 10minutes I will get back to you.
oh and I will also check my email
thanks
Old 09-17-2005, 08:47 PM
