Unhappy Removing Temp Sender
Does anyone have any tricks or suggestions... I just can't seem to get anything down to remove the temp sender in my 930 so that I can do the numerical temp gauge conversion.
Any pointers would be MUCH appreciated.
Rob Montgomery
'88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running
Old 09-24-2005, 06:32 PM
kqw kqw is offline
You should use a "crow Foot" to get in there. Make the job a lot easier.
The Fox
Carrera
Old 09-25-2005, 05:29 AM
fred cook's Avatar
Cool Sender removal....
Be careful about putting too much pressure on the sender. They tend to be really stuck so it is better to remove the mounting block, put it in a bench vice and then remove the sender. If you over torque the sender while it is mounted to the engine, you can strip the threads in the rear engine cover!
BE CAREFUL!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 09-25-2005, 06:36 AM
DonMo's Avatar
Send a message via AIM to DonMo Send a message via Yahoo to DonMo
A warm engine, pbblaster and a little luck. Don't be afraid to use a little cheater bar for additional torque.
DonMo
1984 911 Carrera Targa
3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip
Columbia, SC
"Go Hokies"
Old 09-25-2005, 04:31 PM
syncroid's Avatar
I think he is talking about the oil temperature sender, not the oil pressure sender. You just need to get a longer 19mm wrench.
Dan
2002 996 C4 Cab w/ Jake Raby 4.0
2024 Tacoma TRD Offroad 4x4
2003 Range Rover HSE
Old 09-25-2005, 04:35 PM
