fred cook's Avatar
Cool Ole sparky....
If the original, stock Bosch system is working, keep it! If the Bosch CDI goes belly-up, consider the MSD 6A or 6AL units. They work well, are easy to install and can be bought for about 1/2 the cost of repairing a Bosch unit. You can pocket the extra $$$ or use them to buy a set of Magnacor (or other quality) wires.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 09-29-2005, 01:45 PM
WOW thanks for a the advise, and i didnt realize it was such a complicated subject...but yes my ignition probably works fine but it is an 83 and do not know if it has been replaced or its the original, so i think i may be doing myself a favor by replacing it soon before it leaves me stranded on the freeway...and i did not want to pay the big money its costs for a new bosch, i was looking for a possible cheaper alternative...thks again....and anymore info you guys may have... Damian
Old 09-29-2005, 10:09 PM
RandyF's Avatar
Damian,
I would take Fred's advice, "If the original, stock Bosch system is working, keep it!". My understanding is that the stock units can last indefintely, so why replace it if it's working? If you do replace it with another CD unit, hang on to the old one in case the new one quits on you.
...Randy
90 964 - Weekly Driver
2003 Celica - Daily Driver
78 911 SC - SOLD
Old 09-29-2005, 11:26 PM
jdowty3's Avatar
Switching out the stock Bosch CDI always bring a lot of opinions and some are quite passionate on the subject.
The Bosch unit it good but they do fail over time. You have a unit rebuilt if you want to stay stock. Some never have a problem with Permatunes and other will have nothing but problems. Permatunes seem to have a considerably higher failure rate than Bosch or MSD.
Many owners, including myself, have swap a Bosch for an MSD 6A or AL and feel our motors perform better. Even though, as Loren states, there is no definative technical data to support the claim, my perception is that my SC starts faster, idles better, has smoother acceleration, and picked up a couple MPGs. I had already replaced the plugs wires last year and a new cap and rotor in the spring before I installed the MSD in August. And like many, I plan to keep the Bosch unit just in case I need it.
Jim Dowty
97 911 Coupe (Forest Green metalic, sunroof, leather)
PCA RSR region Insurance chair and Board member
Gruppe B #309
Old 09-30-2005, 05:37 AM
randywebb's Avatar
your unit might last another 10 years - it will give some warning as it goes bad
I'd keep it and save the $$ for something worthwhile, e.g. you could send the money to me...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 09-30-2005, 12:42 PM
Oft-used phrase:
"If it ain't broke, don't fix it."
MHO,
Sherwood
Old 09-30-2005, 12:52 PM
RandyF's Avatar
Actually Damian, if you have a working Bosch CDI you want to replace, I'll pay you $100.00 for it and you can apply that towards the MSD...
...Randy
78 911 SC - SOLD
Old 09-30-2005, 04:29 PM
19 years and 17k posts...
azasadny's Avatar
Sounds familiar...
Originally posted by RandyF
I would personally stick to the stock Bosch unit and definitely not go with the Permatune unit.
My personal one car experience is this: Bought a 78 SC from a So Cal dealer and it soon began stalling on drives. I believe it originally had an MSD unit. The dealer replaced the CD unit with a Permatune, the alternator, plug wires, distributor cap and a few other odds and ends. It ran OK for awhile (500 miles?), but soon started stalling again. By that time it was out of warranty and I took it to another mechanic who suggested I replace it with a Bosch CDI. I was too cheap to take his advice and put in another Permatune. It started stalling again, and I tried various other fixes, such as having some of the ignition related wiring replaced. The car continued to stall.
I took it to another mechanic recommended by several others and he insisted it was the CD unit and suggested I replace it myself with a Bosch unit. I purchased a rebuilt Bosch unit from a Porsche supply house in Florida, and it's run great for almost 3000 miles now. I should mention that the last mechanic also identified that part of the distributor was frozen stuck and wasn't changing the spark advance. So that may have been a factor in the early demise of the Permatune units (not my area of expertise...), but I wouldn't give Permatune another chance myself.
I've had 2 PermaDoom units fail on me. I'd recommend the stock Bosch unit. Buy a good used unit here on the used parts forum...
Art Zasadny
Learning the bass guitar
www.ford.com
Old 09-30-2005, 07:40 PM
86 911's Avatar
Send a message via AIM to 86 911
I would go Bosch, NOT Permatune. I created a thread and listed some pros and cons of the Permatune and Bosch unit:
Bosch CDI unit. Some Questions...
Matt
'76 Porsche 911 with '78 3.0 SC engine
'71 VW Bus
'14 VW Passat (toddler hauler & wife approved ride)
'03 Subaru Baja original yellow & silver
Old 09-30-2005, 09:12 PM
thks for all the info and especially the info on the bosch units, think i probably go with a msd and will diff. hang on to my used unit....
Old 10-02-2005, 11:57 PM
Greyn57's Avatar
what about a Crane Hi 6 Fire Ball ignition unit.
Just fitted one to my 2.4MFI and it works great. Nothing wrong with my Bosch CDI just tucked it away in the parts pile. Looked at both the MSD and Crane units. Went with the Crane unit because it has the internal and adjustable rev limiter. No plug in modules to mess about with.
The unit limits revs very softly too.
64 T34 Karmann Ghia with 2.4MFI flat 6 power. "woo hoo"
Old 10-03-2005, 03:07 AM
Originally posted by Lorenfb
www.systemsc.com/technical.htm ) under
Ignition Systems.
Some after-market systems produce multiple sparks per plug firings, which has questionable value
being localized to one area in the combustion camber and because of the multiple spark timing
compared to the speed of the combustion process, i.e. no additional later spark energy enhances
the combustion process.
It also says the actual pulse time is shorter with the multi-spark systems which leads to worse combustion.
Old 10-08-2005, 01:27 PM
PorscheGuy79's Avatar
Originally posted by bb80sc
The best setup is a pre-74 911 with stock ignition.....geeesh.
Yes, the Bosch is reliable, but even they fail. If you want a more affordable solution, which in some accounts is just as good, go for the Permatune or the MSD. Me? I went with MSD in my 80SC and had no issues, and infact, it ran better. Now, I did have to replace the wires and coil as well, so it's hard to know "what" made the car run better. I guess I do not understand why some folks say MSD does not work as well and other swear by it.
Just to add this in. My car had no records or indication of servicing the stock Bosch ignition system so I thought I would go ahead and replace the rotor, cap, and plugs. I noticed a much improved smoothness to the motor and better running condition. I dont want to say power because people on this board just roll their eyes way someone says they felt more power but I can say it had a bit more spunk. Whatever that means you to, I think the power people might be feeling with MSD etc. might just be the same as a refreshed ignition system.
Matthew
“Sometimes the questions are complicated and the answers are simple.”
Old 10-08-2005, 01:52 PM
D idn't E arn I t
RANDY P's Avatar
Permatune is unreliable junk. Against board advice I had one installed (I gave it a chance) when my 24year old Bosch finally died, and within 3k miles it was dropping out when hot. Replaced it with a used Bosch and haven't had a problem since. Can't speak of the MSD on a 911 but use them all the time on my domestics and they rock.
Permatune is not an option if you intend on having a safe, reliable car. However, it did seem to run slightly better with the Permatune vs. Bosch .
rjp
In the movies only bad guys sleep in king size beds.
Old 10-08-2005, 04:01 PM
