IAN IAN is offline
Any trick to seperating hub from rotor?
I'm taking it all apart. The struts are off the car.
I have removed the bolts that hold the rotor to the hub but I can't get the hub to seperate from the rotor. Any tricks?
I want to avoid big hammer action- although I would rather hit the rotor as they are cheaper than hubs...
Thanks,
Ian
Old 11-28-2005, 10:53 AM
adomakin's Avatar
lots of little hits with a plastic hammer, working round it as you go. and some heat perhaps..
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 11-28-2005, 11:09 AM
I just drop the whole assembly from a height of 3 ft making sure the rotor hits the pavement first. The hub usually dislodge from the rotor when the impact shears the rusted together parts.
Old 11-28-2005, 11:12 AM
Somewhere in the Midwest
MotoSook's Avatar
A steel hammer on the OD of the rotor will do it. Just tap it around and the rust will let go. The taps witht he hammer will break loose the rust scales will help your cooling too.
Old 11-28-2005, 11:27 AM
911SCfanatic's Avatar
heavy cast iron hammer with rubber ends.
Bill G.
'68 911 Ossi Blue coupe
Old 11-28-2005, 11:28 AM
ruf-porsche's Avatar
Dead blow hammer the large size, not the small size.
Old 11-28-2005, 11:29 AM
If you have an air hammer with a flat round attachment (not a chisel, punch or sheet metal chisel)- use on hub area working your way around while hitting with 5 second or so blasts- should eventually separate without damage to the rotor.
Mackskibum aka Dave Austin
'66 911 Work In Progress (#303734)
'85 911 Carrera
06 325XI
'05 Envoy XL SLT
Old 11-28-2005, 11:43 AM
Just did mine the other night. Rubber mallet worked for me. I BBQ'd the hub to get the races out.
Reverend Ray
84 Carrera Coupe "DAS-V2"
GruppeB #2119
Volvo V70SE-Wife mobile
Nissan Frontier-Home Depot mobile
Old 11-28-2005, 11:53 AM
Hopefully you'll clean the grille before the next BBQ at your house.
Old 11-28-2005, 12:08 PM
