WydRyd's Avatar
Question Pic of Cylinder Head Temp Sensor location?
Hi,
Can someone please post a pic of exactly where the Cylinder Head Temp sensor is situated on the '84-'89 Carrera?
I've read it's near Cyl # 3, but can someone please post a pic for me plz?
Is it (i.e: the wire going into the engine) visible when you raise the car and remove the left tyre?
Thanks in advance
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 09-30-2005, 03:54 AM
wheatdog's Avatar
Yep, that's it. There's a rubber seal in the engine tin the white wire goes through. Peel it back and the sensor is hiding there. If you need to remove/replace it, you'll need to purchase or fab up a special tool. I made one out of a deep socket welded to a box end wrench with a slot cut in the side to clear the wire. It's a pain in the a** to reach, but it can be done.
Mike
Old 09-30-2005, 04:45 AM
cjr1's Avatar
Cyl. head temp. sensor location
Merv,
Two pics that show sensor location in my 85 3.2.Wire runs up thru grommet above @ tin work.
Hope these are what you needed!
Let me know if these help!
Chris
"If you think it's gonna cost $1000, ya better budget for $2000."
Chris
85 Carrera 3.2(Back on the road after rebuild)
02 Trans Am WS6
95 Eagle Talon
98 Bravada(sold)
07 G5
Old 09-30-2005, 04:47 AM
cjr1's Avatar
Another shot w/tin
Here's one with tin & rubber seal in place.
Chris
Chris
02 Trans Am WS6
95 Eagle Talon
98 Bravada(sold)
07 G5
Old 09-30-2005, 04:55 AM
WydRyd's Avatar
Great! Thanks for the pics Chris
At least I now know where to look
What's the BOSCH part # for this component?
Merv
'89 911 Turbo Cab
Old 09-30-2005, 05:34 AM
GFCC
Jeff's Avatar
Another approach is to cut the wire and take the old CHT sensor out with a standard deep socket. Tape the new plug end to the clipped wire to help fish it back into the engine compartment. Use a pair of needle nose pliers to tighten the new CHT. Fairly strat forward once you are in there. The hardest part is getting the gromet seated.
Jeff
1976 911 Coupe w/ Euro 3.0 - Sold
1987 Carrera Coupe - Sold
1999 Carrera Cabriolet - Current
Old 09-30-2005, 07:56 AM
