Justin@Athens's Avatar
Send a message via AIM to Justin@Athens
Look what I tore up (parking brake warning?)
So, in the process of my interior strip I think I tore out my parking brake warning indicator?
Can someone please advise me as to where this wire would now be reattached?
I know it followed the autoheat wiring down into the shifter linkage tunnel before, but I cannot find where it severed from the body (if its a ground) or the rest of the circuit (if it leads all the way back to the dash).
1990 964 C4 Coupe & 1991 964 C2 Coupe (current)
1989 911 Targa (sold)
1996 993 Cab. (sold)
1999 x2 Boxster (sold)
2006 Cayman S (my daily)
Old 02-23-2011, 08:32 AM
That is a ground circuit wire and it does lead back to the dash, not to the body. When you pull up on the brake handle, the wire grounds to the chassis and causes the light on the dash to go on as it completes the circuit to the dash light. My cars do not have auto heat but the wire for the e-brake is in a small loom that runs back to the dash. Yours may share the loom of the auto heat wiring. You will need to find the broken end and splice it with what you have to make your warning light functional.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 02-23-2011, 08:48 AM
pete3799's Avatar
I believe it hooks into the auto heat box.
See if you can find a place in the box where it was soldered on.
Pete
79 911SC RoW
Old 02-23-2011, 08:55 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Look for the cluster of wires surrounded by a black plastic/rubber type boot coming out of the tunnel. You should see the same colored wire where it was severed.
'85 Carrera Targa
PCA/POC
Old 02-23-2011, 01:12 PM
Awesome advice as usual gentlemen.
The other end of the wire was hidden within the wiring loom for the autoheat. There is only a brief section that is protected by insulation before it goes into the tunnel where the individual wires are once again exposed and EASILY identified.
Thanks very much guys!
Old 02-23-2011, 08:10 PM
DRACO A5OG's Avatar
At your service
'85 Carrera Targa
PCA/POC
Old 02-24-2011, 09:11 PM
