Guys,
How does one get a new steering bushing onto the steering column completely straight? I tried hammering it in place with a larger socket over the column to try to make it go in straight, but it's gone in a bit crooked. As you can see, the old bushing was completely worn out, causing violent vibration at speed ![]() Here's the new one in place, ready for insertion: ![]() Advice?
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
you might need to remove the old one to get the new one to fit.
Craig Owen 80 911SC Targa 99 Boxster |
Hrmm, I read that once the new one slides in place properly, it should displace the old one further back into the shaft.
My problem is actually getting the new one to slide into the metal housing completely straight. It keeps going in on a slight angle and therefore doesn't go in fully, resulting in it popping back out when the car is driven. I want to fix this once and for all ![]() Tried using a deep socket and hammering it in lightly, but still goes in slightly skewed
I'm with Bill
you probaly don't want to hear this but when I did mine about 2weeks ago I just pushed it in place with my thumbs. I grabbed the clamshell for leverage and shoved. It hurt a little but no pain no gain. My old bushing was in such bad shape though I removed it with a shop-vac.
Electrical problems on a pick-up will do that to a guy- 1990C4S |
Bird. It's the word...
Merv
I've got the metal sleeve that replaces the shagged plastic bush. I ordered by accident a few years back. You slip it over the shaft and tap it down btw the shaft and the bearing. The plastic bushes will continue to fail. Free if you f*k your current project Otherwise try using a punch to tap all around the new bearing gently so it seats square. Or go get some correct diameter and length pipe to use as a drift.
John Forcier Current: 68L 2.0 Hotrod - build underway |
WydRyd, that part is the "bearing" not the "bushing". The replacement procedures are very different. Bushing takes just a few minutes and the bearing will take many hrs. U need to do a search, DO NOT hit that bearing with a hammer.
So, what you're saying is that I've bought the wrong part? Sheeeesh!
Is it the black thing on this page? http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_intacc_pg32.htm#item John, thanks for the offer! Will letcha know!
YES & YES
lets hope U didn't hammer the bearing too hard, good day. |
