Scott R's Avatar
Help with CIS control pressures
OK, I still have a bad idle problem on my 80 SC, She starts up fine when cold, then the idle creeps up as time goes on, if it's just istting it only moves a little if I give it some throttle it starts to go up.
After a while It's hit about 2000 RPM and to get it down to 1100 you have to adjust the idle control screw all of the way clockwise.
If you shut it down it can not be restarted without advancing the idle control screw a few turns. Today I took control pressure readings and here they are: (and and I also removed the CSV and cleaned him up as well, and I can confirm that he does not appear to be leaking.)
Cold Control pressure: 58 PSI
Unpluged WUR first start, motor running: 36~38 PSI (fluctulates)
Plugged in WUR pressure rises quickly to 55-57 and holds
After 30min 22 PSI still in system
Started again pressure is low around 35 PSI
Visual inspection of the AAR shows that after engine is warm and running it is 100% closed.
Thoughts?
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-02-2005, 05:20 PM
Scott R's Avatar
Oh forgot to add that I just checked the CO as well and it's ok. However after I stop the engine warm, then try and retstart it, it of course as I mentioned above idles low if at all, and the hydrocarbons are very low as well.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-02-2005, 06:09 PM
Scott R's Avatar
Bump for help,
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-02-2005, 09:06 PM
Another bump - I'm having a similar problem with my 82 SC.
'82 911SC
Old 10-09-2005, 07:57 PM
Sounds like an aux air regulator problem. It is on the right side between the intake runners. Pull the electrical plug -- it should have 12v on it when the engine is running.
If it has the cirrect voltage, then it may be suffering internally. Run a search for AAR and you should come up with some good information.
Old 10-10-2005, 08:44 AM
In your second post what you're saying is that you're not getting enough fuel. Have you run some injector cleaner recently? Is your fuel filter OK or did you get some dirty gas?
If you're doing it right, you're cold control pressure is high. "Plugged in WUR pressure drops quickly " from what?
When did this start? Did you do something that started it?
Old 10-10-2005, 09:04 AM
SC-targa's Avatar
I've suffered the same problem on my 82. On my car, it's much worse on hot days.
See what happens if you unplug the O2 sensor. That helped, but did not cure mine. I'm thinking that I may have a vacuum leak under the airbox that is temperature sensitive. Like you I checked the AAR and all the other devices plumbed into the system. I actually disconencted them and plugged the ports, to no avail.
Good Luck,
Jerry Kroeger
82 911SC Targa
(05 Boxster S ) gone, but not forgotten
87 Suzuki GSXR-1100
1953 MG TD Mk II
Old 10-10-2005, 09:30 AM
Scott R's Avatar
That's a mistake on my part, I meant that once the WUR is plugged in the pressure climbs to 55-57.
And no on the injector cleaner, in fact I am leaning towards injectors now as it looks like I am bleeding pressure out the injectors after the system is shut down.
I keep 19 PSI in front of the fuel distributor, but I appear to have an injector or two that never closes.
And this has happened since I removed the CIS system during my engine drop, The car is very drivable, it just does not like to start when it's been running and then shut down for a 10 or so min. And of course the idle is all over the place.
I did replace the WUR this weekend with another that I have, and it did not really change anything.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-10-2005, 09:38 AM
What you've said now about removing the CIS would have me suspect a vacuum leak.
Old 10-10-2005, 09:53 AM
Scott R's Avatar
If there is then it's not in the usual places. I replaced all of the intake boots, and all of the injector seals while it was out, new o-ring for the throttle valve as well. Air boot is good, and I can open the oil fill cap and get the expected drop in RPM's. And if I simulate a vacuum leak, like pulling a line going to the distributor I get a CO change.
It would have to be a crack in the air box in a place that I can't see, or something like that.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-10-2005, 09:59 AM
byrd101's Avatar
Have you checked the decel valve. If it's bad it would cause a vacuum leak and a slow increase in idle. I had that problem a few years ago. It's easy to troubleshoot, just pull and plug the vacuum line. I was able to run without it for a week or so.
Old 10-10-2005, 11:03 AM
Scott R's Avatar
I have unplugged it in the past and noticed that it did nothing, I will try and run without it, thanks for the suggestion!
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-10-2005, 11:38 AM
Everyone - Thanks for the info.
The electrical plug on the Aux Air Regulator had come loose. I reconnected the plug and the idle is back to normal. Thanks again!
'82 911SC
Old 10-10-2005, 07:16 PM
Scott R's Avatar
Oh man I hate you. Three local mechanics and no one can figure my issue out.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-10-2005, 07:26 PM
vash's Avatar
scott, you need to test cold control press with the wur wire disconnected.
then reconnect and get warm press, car runing.
is that micro switch on the throttle working properly?
poof! gone
Old 10-10-2005, 09:19 PM
Scott R's Avatar
I just removed the throttle housing and adjusted the throttle switch with an OHM meter. And the cold control pressure is 34PSI.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-10-2005, 09:35 PM
