MPegler's Avatar
Self install Cat Bypass
Is this a fairly simple job? I'm keeping the stock muffler. I'm pretty experienced with DOY car repairs, but this would be my first Porsche project.
I don't have a torch etc., so I'm hoping that things come apart as expected. What should I watch out for?
Thanks,
Mike
'88 Commemorative Edition Carrera
Cabriolet
'87 Catalina 30
Old 10-03-2005, 10:52 AM
Eugene at Pelican Parts's Avatar
Rusty bolts. If doing it with the engine out, have an angle grinder ready. If it's still in, then a good dremel with lots of cutting disks. The nuts are usually 12mm, so be careful not to round them off with a 13mm wrench.
Eugene (Formerly) at Pelican Parts
Pelican's E-Commerce Guy, 2003-2011
2001 330i Sport
1983 911SC Coupe (sold)
Old 10-03-2005, 10:55 AM
watch out for goblins. they live in there.
its easy. if you need help im in north hollywood
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 10-03-2005, 10:58 AM
Not bad at all. Make sure you have replacement nuts bolts and gaskets. The gaskets shouldn't be reused.
Chris
'80 SC
Old 10-03-2005, 11:07 AM
ausgezeichnet's Avatar
I hit all my bolts with PB balster several days before the removal. All came off with normal wrenching.
Mike
'84 911 Carrera Coupe (totaled)
'83 911 SC Coupe
‘06 Aston Martin Vantage V8
Old 10-03-2005, 11:18 AM
fuelie600's Avatar
It all depends on how rusty the nuts and bolts are. I had to cut (grind) all of the heat shield bolts off, then I had to cut the three bolts between the cat and the muffler. I was able to remove 3 of the 6 bolts between the cat and the header pipes. I had to cut the other 3! This was after soaking all of them in PB blaster for two days in a row prior.
It's not a hard job, but it requires lots of patience.
Good luck!
Evan
1987 sun roof coupe
Old 10-03-2005, 04:51 PM
Registered abUser
TerryH's Avatar
Heat shield was missing on mine already, but I did take the left rear tire off so I could have a straight shot at a couple bolts. You want to make sure you give it your best shot the first time because if the bolts/nuts round off, then you're grinding. Mine were rusted, but came off pretty easy.
It was only after I removed the cat to install the bypass pipe, did I see the cat was empty. I bought new hardware/gaskets and reinstalled the gutted cat instead of the bypass pipe. Stock looking at least means I can pass visual emissions without having to R&R that bypass pipe.
'81 911SC Coupe SOLD
Old 10-03-2005, 05:47 PM
