New to Porsche, already a problem (part 2)
Thanks for the support and advice once again...I feel like a true member in the Porsche world after completing a few projects.
I have purchased "101 Projects". Invaluable information here and in that book. I love the car. Its a blast to drive and the looks! you get...wow. I have done a mini-tune up. Plugs, dist. cap, and rotor button. I replaced the shifter cup, rod bushing, and the bushings in the rear coupler (tough without a press). The shifting is light years better but it is still popping out of second gear. The second gear syncro...I believe is worn out. I think I will change the trans fluid with an easy to find gear oil. Drive it for a few hundred miles then replace with the Swepco 201. Maybe a good flushing with help. Any other good advice to help a worn out transmission would be appreciated. Thanks Eric I even got my XM reciever hooked up this weekend. Piece a cake! |
Author of "101 Projects"
Try the Swepco. If it doesn't work, then it's probably time for a rebuild. Not too much you can do to get away from that with this popping-out-of-gear problem...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series 101 Projects for Your Porsche 911 How to Rebuild & Modify Porsche 911 Engines 101 Projects for Your Porsche Boxster & Cayman 101 Projects for Your Porsche 996 / 997 SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
durn for'ner
Hi Eric,
If you wanna read the essence of misery when it comes to changing gear lube - go to my current thread "Giving up on gear lube change". Plenty of great advice and a good example of how fantastically helpful and supportive the guys on this forum are ! (Mind you I am not implying you don΄t know how to change gear lube - just that the thread could be worth reading). Cheers,
Markus Resident Fluffer Carrera '85 |
