911 Charging system
I have a 1984 911 Cabriolet and there is something wrong with the charging system. I just replaced the alternator and the battery with new ones and when i test the system with the lights, heater, etc. on, the voltage on the system drops to 12.2 volts or below. When i test the system with no accessories on, im getting 13.4 volts. Does anyone have any idea as to what I should be looking for to solve this problem?
Old 10-03-2005, 12:02 PM
you tested at 2k+ rpm ?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-03-2005, 09:23 PM
charging system
Does the voltage increase when you rev the engine? Your
voltage should be in the vicinity of 14.1 to 14.4 volts.
76 911S
81 911SC
66 912 V8
66 912 2.2 with nitrous
70 914 project car
Old 10-03-2005, 09:24 PM
yes, i did test under a load at 2000+ rpm and im recieving between 12.2 and 12.4 volts
Old 10-03-2005, 10:06 PM
If you installed a rebuilt alternator it's probably ng. That's not unusual.
If it's a brand new alt I'd check the alt voltage directly at the alt.
I'm assuming the starter connection, battery connection and the 14 pin eng comp connection is good.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-03-2005, 10:14 PM
The alt is a brand new part from Porsche. The only time that I have this problem is when the headlights or the heater is on.
Old 10-03-2005, 10:23 PM
good.. if it's a local dealer tell them to put a scope on Their alt.
otherwise maybe someone has a better idea ?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-04-2005, 12:51 AM
Your battery must be fully charged for the test to be valid.
Joe
Old 10-04-2005, 09:36 AM
