Does anyone know anything about...
car? Besides the fact that the guy can't spell and his grammar is for the birds!
Also does it look like this car will pass smog in ca. old exhaust would be put on, but what about the twin plug. ic....?
72 911 Although it is done at the moment, it will never be finished. Last edited by tobluforu; 10-03-2005 at 06:54 PM.. |
Author of "101 Projects"
Unlikely that it would pass smog, as it's been so highly modified...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Unregistered
The only things that would cause it to fail the smog test in Ca would possibly be the exhaust if, the k&N, the chip, and the larger injectors.
Even with the factory chip the larger injectors could cause problems. If the factory exhaust were re-installed, the factory intake filter system, the factory chip, and the original injectors, it should pass. The turbos and intercooler don't make any difference at all unless it is under boost. it is also possible that the chip programmer did his job well enough that he maintained the clean running at anything less that boost, but you still have to pass the visual and on that new of a vehicle that means that any and all detectable modifications have to be CARB certified. Very hard to pull off. |
If you want to buy it I'd be happy to register it in NH.. I could keep it summers, you can drive it the other 9 months!!!
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
Thanks all.
72 911 Although it is done at the moment, it will never be finished. |
