Carl83911's Avatar
It seems I may have overfilled...
I posted sometime last week that my 83 SC has developed a leak. I remember that I began noticing the leak after I've topped off the oil and remembered that my oil level read at 3/4 full.
I drained a little bit of oil last friday and allowed the car to sit all weekend. I haven't noticed any leaks since.
I have someone coming over Tuesday to change the endine cooler O ring. I may have to cancel that order if it's not leaking.
Question: If i've overfilled with oil and the oil was leaking somewhere would it pool around the o ring area and eventually drip down to the heat exchangers and eventually drip on my garage floor?
I may have to just clean that area where the oil deposits have built up and see if the o rings are actually leaking.
Carl,
Old 05-01-2006, 09:39 AM
Friend of Warren
Not positive, but I believe on the SC the airbox drain hose empties on the same side as the oil cooler. Thus if oil got sucked into the airbox it would run out on the same side of the car as the engine oil cooler.
Kurt V
Old 05-01-2006, 10:11 AM
9elf's Avatar
I had the exact same problem.
Oil sloshes from the oil filler neck to the cis air intake just past the air filter, before the air flow sensor. From there it goes out a drain line to a spot just near the starter motor.
See the drain near the starter below.
Best to keep the oil level on the low side (not below the low level mark on the dipstick though).
This has been my experience.
“If you want to win anything- a race, yourself, your life- you have to go a little berserk” - Dr George Sheehan.
“Happiness is different from pleasure. Happiness has something to do with struggling and enduring and accomplishing.” - Dr George Sheehan.
Old 05-02-2006, 02:09 AM
9elf's Avatar
That was my black car at night.
I'll try the photo again.
Old 05-02-2006, 02:14 AM
9elf's Avatar
Nope.
Anyway, this is what it looks like in black.
Old 05-02-2006, 02:15 AM
Wer bremst verliert
JohnJL's Avatar
Try down-sizing the photo, that should work.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 05-02-2006, 02:57 AM
For pix:
Just learned this too. I used MS Picture Manager (default for my PC) and resized (edited) the shots to the smaller "document" size and now they upload.
Hope that helps
-Chris
1987 Guards Red Targa (sold)
2006 Toyota Tundra DC 4x4, the "man-e-van"
1998 CR500
Well on the fringe......
Old 05-02-2006, 11:37 AM
9elf's Avatar
At risk of becoming a monotonous bore, I'll try the picture again, resized.
If this is still black, please accept my apologies.
Old 05-02-2006, 01:42 PM
9elf's Avatar
Old 05-02-2006, 02:01 PM
Carl83911's Avatar
Originally posted by cbeers
For pix:
Hope that helps
-Chris
I also tried attaching pics on my initial post but they were showing black. I'm using photoshop as my default.
Carl,
Old 05-03-2006, 07:58 AM
