Troubleshooting Cruse Control
OK my Cruse Control worked two weeks ago. Went to use it yesterday and no cruse control. I replaced the steering wheel, and adjusted the idle and mixture. Just an FYI I don’t see how this would affect cruse but you never know. Here is what I have done so far. Did a search on the forums. Checked the fuse. Pulled the control lever and turn on and off the car. Looked for any disconnected hoses in the engine compartment. I have a 44 mile one way commute to work and like the cruse so do tell me to disconnect it or sell it. |
Did you do any clutch adjustment/alteration? My cc won't work unless the clutch pedal is all the way out.
-Matt 1985 Targa |
No clutch work, I have an 88 Carrara with a hydraulic clutch dose that matter?
The first thing I would check is the cruise control brake switch. It is bolted to the floor located just to the right of the gas pedal inside the center tunnel. It is operated by a lever that attaches to the brake pedal shaft. The switch can come loose and move. The lever should just contact the switch when the brake is in its normal position. Use a test light or meter to check. I found it easier to remove the gas pedal to do the adjustment.
Good Luck Andrew
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires '86 944NA, Sunroof Delete, Track Rat, Full Cage '72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic |
Thanks I will check that
Recreational User
I think Andrew is talking about the clutch switch....the brake switch is behind the master cylinder in the back of the trunk unless they moved it after '86.
Also don't forget to check the relay which is in the main fuse/relay bank. |
Typing faster than I am thinking.......porschenut is correct, it is the clutch switch.
Andrew
