drag racing the short bus
dd74's Avatar
Oil cooler help, please...Spal and oil cooler air scoop
It is becoming more evident that I should drop the trombone cooler I have on my car and install the Carrera cooler I bought a few months ago. With that, I've already located through Pelican the correct mounting brackets and hoses that I need for the Carrera cooler. I would also like to install a fan that can be operated manually and possibly an oil cooler air scoop.
My question is, are both the oil cooler air scoop offered by Pelican and an electric fan overkill? Also, I am looking with much interest at the Spal 7.5-inch fan, which seems to have a good reputation on this board. I would want to operate this fan manually, via a switch.
I'd like some feedback from anyone who uses the Spal 7.5-inch fan and/or an oil cooler air scoop.
As for the Spal fan, which did you purchase? A "push" or "pull" version? 12 or 24 volt? And if you use the Spal 7.5-inch fan, what mounting brackets did you use from Spal for the fan?
And to repeat the first question, is the oil cooler air sccop and fan overkill?
My car is a daily driver and as is the case with L.A., sometimes caught in very bad traffic.
Thanks for your time.
Old 10-06-2005, 10:44 PM
Administrator
Jack Olsen's Avatar
I'd skip the scoop, personally, and get a pusher fan.
Old 10-06-2005, 10:49 PM
dd74's Avatar
Thanks, Jack. That sounds like a good plan.
Here's a photo of the fan btw:
Old 10-06-2005, 10:51 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Re: Oil cooler help, please...Spal and oil cooler air scoop
David,
I used to see 240-250 with only the trombone on the 405 in the Sepulveda pass.
with the manually/auto fan and the cooler scoop, I see it get to 215 maximum, then back down to 210 after making it right about the 405/5/14 freeway split.
Old 10-06-2005, 11:14 PM
jdowty3's Avatar
Get the push fan and, instead of the scoop, have your bumper notched to get easier air flow to the cooler.
Jim Dowty
97 911 Coupe (Forest Green metalic, sunroof, leather)
PCA RSR region Insurance chair and Board member
Gruppe B #309
Old 10-07-2005, 07:00 AM
PCA7GGR's Avatar
I have apair of new flex hoses that mount between the hard lines and the cooler. Let me know if youstill need them. Thanks
Sergio
The GT Lid Whisperer
PCA 42yrs - National DE Instructor / Ex-RGruppe #197
'19 718 Cayman S (9th Porsche/1st with PDK)
'14 Subaru Forester XT (Porsche support vehicle)
Old 10-07-2005, 07:12 AM
The scoop puts in more cfm at freeway speeds than the fan but the fan puts in more cfm sitting in traffic.
Jerry
Old 10-07-2005, 07:35 AM
dandrews64's Avatar
Use the scoop and fan. I do, it rules.
7.5" pusher, 12 volt. fanman.com if Noah's doesn't work out. It will come with some additional attachable mounting 'feet' and you will need to use one.
Manual switch. Don't know what year 911 you have, but on my '82SC on the left side of dash between the left most two guages, you will feel a hole behind the vinyl/leather cover. You can mount a mirror/headlight washer switch in there. It is for the rear wiper switch, so if you have that then the location is already in use.
You also need a bosch relay to act as a soleniod b/c that little switch can't handle the juice. If you need a part number and hookup instructions, shoot me a PM, and I'll dig it up.
This is all good advise I followed from another Pelican - Vash. Here's the thread for his install: my carrera cooler install, so far
Here are some pics to show what I'm talking about:
Doug Andrews
1982 911SC Targa
2008 Silverado Duramax 3/4 ton
2004 Armada
1999 Honda XR400
Old 10-07-2005, 08:10 AM
dd74's Avatar
This is what I love about you guys. You're all Johnny-on-the-spot when a fellow Pelican is in need.
Noah: pm'd you.
Sergio: pm'd you.
Doug: pm'd you.
Anyone else want to be pm'd?
Thanks guys!
Old 10-07-2005, 10:30 AM
Senior Member
Good info!
JoeA
Old 10-08-2005, 10:35 AM
dandrews64's Avatar
horn relo mount
Here is Vash's handywork to reposition the horns.
Cut half the brack off and cut the original mounting tab from the bracket.
Then, reshape the mount plates that connect the horns to the bracket as necessary after removing the welded on nuts (Vash twisted his off, I ground mine off). Then, these mounting plates (1) shares the bracket to headlight bucket mount point and (2) the other uses the existing hole in the bracket - evidenced on mine by the shiney head of the nut.
Doug Andrews
1982 911SC Targa
2004 Armada
1999 Honda XR400
Old 10-11-2005, 11:29 AM
drl911's Avatar
I am going to add the Spal fan to my carrera cooler this winter, as well. The picture in this thread shows it attached to the middle of the cooler. I have seen others attach it to the top of the cooler. Any theories on WHERE to attach the fan to the cooler (top, middle, bottom)???
Thanks,
Dan
Can I ask you a question? Sure, what is it? An interrogative statement that tests ones knowledge, but that's not important now....
'86 Carrera . . . '87 951 destroyed by drunk driver ... '01 Boxster S. . . '04 Cayenne S . . .
Old 10-11-2005, 01:38 PM
dandrews64's Avatar
middle of cooler is just where it fit on my car to provide maximum clearance between tire and cooler.
Doug Andrews
1982 911SC Targa
2004 Armada
1999 Honda XR400
Old 10-11-2005, 01:55 PM
dd74's Avatar
Yessir: I'm getting all the materials together now...(thanks, Noah, Sergio and Doug).
It was suggested I use a rear wiper switch to hardwire the fan for on/off purposes. The switch would actually go in the dash between the speedometer and clock, where there is a small faux toggle switch cover that resembles a power window switch. Originally, I wanted to go through my fog light switch in the middle-top portion of the dash.
What do you guys think about this idea?
Old 10-11-2005, 02:00 PM
dandrews64's Avatar
Should work.
I have the fan mount foot and the relay paperwork all gathered to send you, just gotta get it sealed up and in the mail !
Doug Andrews
1982 911SC Targa
2004 Armada
1999 Honda XR400
Old 10-11-2005, 02:03 PM
Very nice Doug, you are becoming the Pelican cooler man
-Chris
1987 Guards Red Targa (sold)
2006 Toyota Tundra DC 4x4, the "man-e-van"
1998 CR500
Well on the fringe......
Old 10-11-2005, 02:06 PM
dd74's Avatar
Thanks, Doug. I truly appreciate your help.
Old 10-11-2005, 02:10 PM
dandrews64's Avatar
I have much to pay forward. Cliff, Chris, and Tim were a tremendous help to me on my cooler project.
Doug Andrews
1982 911SC Targa
2004 Armada
1999 Honda XR400
Old 10-11-2005, 02:13 PM
Just wait till we start digging into those spring plate bushings!
-Chris
1998 CR500
Old 10-11-2005, 03:13 PM
