I need your help
My 1990 911 keeps going dead as I pull up to a stop sign, red light, etc. I have a guy that will work on it without losing a couple of rooms of my house and a small child. Although he is an excellent mechanic, he is not that familiar with Porsche engines. He needs to know what to change out. Here are the following guesses:
1. DME relay
2. Possible vacuum leak
3. Ignition coil and wires
4. Torque the manifold bolts down. Check the torque setting. I know on the carrera's it at 18 ft/Lbs
5. I was told there are 2-3 switches/relays that could be the problem, but I am not sure what they are called (any idea).
I know it is hard to diagnosis someone's problem without seeing the car, but I sure appreciate you trying. Thanks.
Old 10-11-2005, 06:11 AM
AFJuvat's Avatar
Head temperature sensor. Located on cylinder 3 (left side of the motor, rear cylinder)
Bad DME relay: Car will not start
Vacuum leak: Car will run like garbage
Ignition: Same thing
Manifold bolts: Not likely
AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 10-11-2005, 06:16 AM
Thank you so much. So, forget the vac and ignition and concentrate on the head temperature sensor?
Old 10-11-2005, 07:39 AM
