drag racing the short bus
Oil cooler help, please...Spal and oil cooler air scoop
It is becoming more evident that I should drop the trombone cooler I have on my car and install the Carrera cooler I bought a few months ago. With that, I've already located through Pelican the correct mounting brackets and hoses that I need for the Carrera cooler. I would also like to install a fan that can be operated manually and possibly an oil cooler air scoop.
My question is, are both the oil cooler air scoop offered by Pelican and an electric fan overkill? Also, I am looking with much interest at the Spal 7.5-inch fan, which seems to have a good reputation on this board. I would want to operate this fan manually, via a switch. I'd like some feedback from anyone who uses the Spal 7.5-inch fan and/or an oil cooler air scoop. As for the Spal fan, which did you purchase? A "push" or "pull" version? 12 or 24 volt? And if you use the Spal 7.5-inch fan, what mounting brackets did you use from Spal for the fan? And to repeat the first question, is the oil cooler air sccop and fan overkill? My car is a daily driver and as is the case with L.A., sometimes caught in very bad traffic. Thanks for your time.
Administrator
I'd skip the scoop, personally, and get a pusher fan.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Thanks, Jack. That sounds like a good plan.
Here's a photo of the fan btw:
In the shop at Pelican
Re: Oil cooler help, please...Spal and oil cooler air scoop
I used to see 240-250 with only the trombone on the 405 in the Sepulveda pass. with the manually/auto fan and the cooler scoop, I see it get to 215 maximum, then back down to 210 after making it right about the 405/5/14 freeway split. |
Get the push fan and, instead of the scoop, have your bumper notched to get easier air flow to the cooler.
Jim Dowty 97 911 Coupe (Forest Green metalic, sunroof, leather) PCA RSR region Insurance chair and Board member Gruppe B #309 |
I have apair of new flex hoses that mount between the hard lines and the cooler. Let me know if youstill need them. Thanks
Sergio The GT Lid Whisperer PCA 42yrs - National DE Instructor / Ex-RGruppe #197 '19 718 Cayman S (9th Porsche/1st with PDK) '14 Subaru Forester XT (Porsche support vehicle) |
The scoop puts in more cfm at freeway speeds than the fan but the fan puts in more cfm sitting in traffic.
Jerry |
Use the scoop and fan. I do, it rules.
7.5" pusher, 12 volt. fanman.com if Noah's doesn't work out. It will come with some additional attachable mounting 'feet' and you will need to use one. Manual switch. Don't know what year 911 you have, but on my '82SC on the left side of dash between the left most two guages, you will feel a hole behind the vinyl/leather cover. You can mount a mirror/headlight washer switch in there. It is for the rear wiper switch, so if you have that then the location is already in use. You also need a bosch relay to act as a soleniod b/c that little switch can't handle the juice. If you need a part number and hookup instructions, shoot me a PM, and I'll dig it up. This is all good advise I followed from another Pelican - Vash. Here's the thread for his install: my carrera cooler install, so far Here are some pics to show what I'm talking about:
Doug Andrews 1982 911SC Targa 2008 Silverado Duramax 3/4 ton 2004 Armada 1999 Honda XR400 |
This is what I love about you guys. You're all Johnny-on-the-spot when a fellow Pelican is in need.
Noah: pm'd you. Sergio: pm'd you. Doug: pm'd you. Anyone else want to be pm'd? Thanks guys!
Senior Member
Good info!
JoeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
horn relo mount
Here is Vash's handywork to reposition the horns.
Cut half the brack off and cut the original mounting tab from the bracket. Then, reshape the mount plates that connect the horns to the bracket as necessary after removing the welded on nuts (Vash twisted his off, I ground mine off). Then, these mounting plates (1) shares the bracket to headlight bucket mount point and (2) the other uses the existing hole in the bracket - evidenced on mine by the shiney head of the nut.
I am going to add the Spal fan to my carrera cooler this winter, as well. The picture in this thread shows it attached to the middle of the cooler. I have seen others attach it to the top of the cooler. Any theories on WHERE to attach the fan to the cooler (top, middle, bottom)???
Thanks, Dan
Can I ask you a question? Sure, what is it? An interrogative statement that tests ones knowledge, but that's not important now.... '86 Carrera . . . '87 951 destroyed by drunk driver ... '01 Boxster S. . . '04 Cayenne S . . .
middle of cooler is just where it fit on my car to provide maximum clearance between tire and cooler.
Yessir: I'm getting all the materials together now...(thanks, Noah, Sergio and Doug).
It was suggested I use a rear wiper switch to hardwire the fan for on/off purposes. The switch would actually go in the dash between the speedometer and clock, where there is a small faux toggle switch cover that resembles a power window switch. Originally, I wanted to go through my fog light switch in the middle-top portion of the dash. What do you guys think about this idea? |
Should work.
I have the fan mount foot and the relay paperwork all gathered to send you, just gotta get it sealed up and in the mail !
Very nice Doug, you are becoming the Pelican cooler man
![]() -Chris
1987 Guards Red Targa (sold) 2006 Toyota Tundra DC 4x4, the "man-e-van" 1998 CR500 Well on the fringe...... |
Thanks, Doug. I truly appreciate your help.
I have much to pay forward. Cliff, Chris, and Tim were a tremendous help to me on my cooler project.
Just wait till we start digging into those spring plate bushings!
![]() -Chris
