Bird. It's the word...
915 Output flange issues ( g/b swaping)
Okay, here's my dilema...
I'm converting my 69 sporto to a 915. Box is a 915/63 with 6 bolt output flanges. I have just put brand new rear bearing in and don't really want to change wheel flanges from the 4 bolt pattern to 6 bolt. I've done the homework with the shafts and it appears that I cannot put a 4 bolt CV on one end and a 6 bolt CV on the other as the shafts are a different diameter at the splines. This is probably a dumb question; can I use the output flanges from the 69 sporto box and install them in the 915? What advice can you 915 conversion gurus offer??? Cheers
John Forcier Current: 68L 2.0 Hotrod - build underway |
This is a sad day. I can't believe what I'm reading!
(I would have done it too at some point if I had kept my car) Joe |
Dude! Where's your car?
