In a month or so I'll be putting the car away until spring. One of the things I do is the oil change before storage and immediately after it comes out of hibernation.
My question is this: Should I change the oil filter both times? This seems a waste as a brand new filter sits on the car during storage and is discarded in spring with virtually no miles on it. Or should I care? Thanks in advance, |
Recreational User
For that matter, I've never understood why an oil change should be done both before and after. Wouldn't you be wasting brand new oil with no miles on it?
BTW, in hibernation no one can hear your car scream. |
durn for'ner
I prefer to just change oil and filter once - when I start out in early spring. That way its fresh when I start spanking the engine.
However, I know there are plenty of guys here prefer to change it before hibernation and I can appreciate there motives for that - but in the end really don´t think it matters what strategy you have. As long as its changed yearly. Just listen to me guys - I am starting to sound like a veteran..
Markus Resident Fluffer Carrera '85 |
There is really no reason to change oil when coming out of a few months of storage.
The reason to change both oil and filter on the way in is to get all of the condensation, acid and other contaminants out so that they will not eat away at the static innards.
I will be storing for 5-6 months and the temperaure in my garage flucuates around freezing and is typically damp. Would this make any difference? |
Unregistered
The PH of motor oil drops (becomes slightly acidic) as it gets more miles on it due to the sulfur on the fuel. No where near as bad as it used to be.
Changing the oil before you put it away is a good idea, as long as you run it and circulate it. no reason at all to change it or the filter again in spring, just warm it up easy and burn off any moisture that has condensed. |
Fuchs w h o r e
How about this, dump the oil now and leave it empty. Re-fill in the spring.
Somatic Negative Optimist
No, no, no. Do not leave it empty. There are parts in the engine that will rust without oil. Consider cranking the engine every two weeks without ignition on. (Remove the 6-pin CDI plug on the module (Not the coil cable) and the fuelpump relay) Crank a few revs until the oil light on the dash goes out.
As for an unheated garage, use several old comforters over the car with a 150 Watt flood light on a secure stand on the floor inside to take out the moisture. WINTER STORAGE IN UNHEATED GARAGE Here is what I do: One last long run with injection cleaner in the tank, use up full tank. Change oil and filter. Fill tank (Add Stabil) Wash car top and bottom (Including the wheel wells) Dry car thoroughly, drive a few miles to dry out brakes and bottom Leave oil cap off during engine cooling to expel hot air Spread poly sheet on bare concrete, park on poly Place an open box of baking soda in the car to keep it fresh smelling Treat leather seats with conditioner Trickle charger on the battery, or remove battery Transmission in neutral and emergency brake off Extra 5 lbs. pressure in tires, roll the car a little every week to avoid flat spots and prevent the brake pads to make a rust spot on the rotors Put a little Vaseline on the Fuchs wheels Polish chrome on sunroof assembly Close heater valves (Rodents!) Set up mouse traps or bait Do not use a tarp or poly over the car; it traps moisture! Put 3-4 old comforters over the car with a 150W light bulb inside secure on a little stand and a 60W light bulb resting in a metal hub cap inside the trunk close to the fuse panel (Fuse box lid removed) It prevents oxidation. The two bulbs keep things dry at about 50 deg Fahrenheit (10 deg Celsius) I do not start the engine during winter but crank it every two weeks with the CDI, and fuel pump, disconnected to circulate the oil An old radio plays Rock-One-0-One 911-music while the snow flies.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Jesus !!!
Way too much time on your hands. Just drive it occasionally. Even the arctic circle gets a pretty day now and again |
coolcavaracing.com
Hay Markus - 911 Posts, way to go
Pål (Paul) - The Norwegian lost in Finland... 1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!) come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
No driving here with all that salt on the roads; it's just not fun.
However, anyone who wants to run in the winter: go for it! I don't mind spending some time for storage preparation so the 911 won't rot away on me. I get a lot of driving in the spring, summer, fall to feed the addiction.
durn for'ner
You bet, Pål !!!
Sooo, whats your oil change strategy ? Once in a blue moon ??
durn for'ner
Bill´s spoken.
And as opposed to me, going with instinct, he knows what he is talking about. I am changing strategy - the old girl will get her oil change before winter hits us. Think I will try changing from 0w40 to 10w40 as well.
coolcavaracing.com
I changed my oil before I did the big drive from London to Stockholm, and then again when I got here (4 weeks back). I am thinking the oil is still fresh and can stay until next summer, and will be changed when the snow is gone!! After that I will decide next year
![]() I am actually considering storing my car in the UK during the winters after this anyway
durn for'ner
Good idea, Pål.
I hear they have a real dry and preserving climate their...
Thanks for the comprehensive list. I've been through this before on the board and I may make some additions. Cheers, |
Wow Gunter!!! I think you had me until the light bulb thingy!!! More power to you but that is nuts! Oh by the way I change my oil and filter right before I put her away for the winter....removes the dirty oil that would sit in the crankcase all winter and she is ready to go the first day of the Spring driving season!!! 15-50 MOBIL 1
944 TURBO!!!! 1982 911 SC Targa (loved but sold!) 2005 Cobalt SS (0-60 in 6.1!!) 2003 BMW 325i ex got in divorce 1969 912 Coupe (sold) PCA Member |
