someone please help me. i have a 1979 porsche 911 coupe and i have a problem. i smell gas in the engine compartment and inside the car. i didnt see any gas driping anywhere what can this be any clues im confused thank you for the help.
sylvester Last edited by sylvester; 11-01-2005 at 02:37 PM.. |
Headlight Stalk Switch?
Sylvester,
Do you notice the smell with your headlights on only? Could be your headlight stalk switch if you don't have relays installed.
Mark '88 Carrera GPW Sunroof Coupe '82 SC Targa (RIP) |
When you take your foot off the accelerator, does the car coast as it should, or does it seem to slow down to quickly? Possible brake caliper binding?
Is it electrical smell, or more mechanical in nature? P.S. Punctuation will help readers understand your questions.
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
Check you fuel tank for any pin-hole leaks. It might be located around mid seam area. Is the smell of gas greater after you fill the tank ?, if so then the hole may be higher up the tank. This is my experience.
POKDUB Porsche 911E |
check your alternator amperage.
is your heat on?.... could be oil on the exhaust also FYI- go buy a halon extinguisher before you accidentally lose the car.
Looking for 87-89 Silver Cab 911, black interior, must be low miles, near pristine, no accidents, well sorted. |
coolcavaracing.com
I had a problem like this, which was really bad after I had filed the car with fuel - turned out to be the rubber tubes between the filler and the tank was getting a bit to old. Next time you get the smell flip open the trunk and see if the smell if in there?
Pål (Paul) - The Norwegian lost in Finland... 1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!) come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
sylvester, don't waste time in self diagnosis, find a porsche repair shop asap. even if you dont use them, and decide to do the work yourself, their experienced six senses could idenitfy a simple issue or possbily save your car from an imminent bad end.
"And there's no cure like travel to help you unravel the worries of living today. when the poor brain is cracking there's nothing like packing a suitcase ..(or getting in the Porsche) and sailing away " Cole Porter, anything Goes" |
My cap gasket defaulted. Many gaskets available even though I said what car it's for to Stoddard.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
