logician's Avatar
Which crossover line with 911 gearbox?
What do you guys with 911 gearboxes ('70/71 vintage) do for the oil crossover line? My race car came with the early flexible crossover line that goes over the bell housing. But that rubber line runs very near the headers (no heat exchangers) and is starting to split. It seems like a bad idea to have this rubber line so close to the headers. I had started to fit a '74 line -- the hard line that goes under the engine. But that one interferes with the clutch cable termination that is flush with the face of the bell housing. I tried bending the pipe with little success.
Is there a good solution for this problem? Does anyone sell a line that works for this application?
-Juan
www.ArtOfRoadRacing.com, Thunderhill, 30 Jan 2011
ArtOfRoadRacing@gmail.com
SM #34, '04 GT3, '73 911s, '70 911 2.7L PRC Toyo Spec #11
Old 10-18-2005, 07:16 PM
randywebb's Avatar
I use the old style hoop one (but my type 911 gearbox is a odd installation - in a '73 w/ an '86 engine)
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 10-18-2005, 10:15 PM
logician's Avatar
Randy, I don't understand which hoop one you mean. Do you use the rubber one that goes over the engine, or the solid one that goes under? If the latter, then how do you avoid the interference with the clutch cable?
-Juan
Old 10-18-2005, 10:55 PM
Grady Clay's Avatar
Juan,
I think you are stuck with the hose that goes over the transmission. I don’t recall any other solution. Is yours with reusable fittings? If so, you can replace just the hose. When faced with that problem, I insulated the hose and put a little heat shield on the header.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 10-19-2005, 01:07 AM
What I ended up doing was cutting up several of the lines that I had and welding up pie slices of pipe to make up the line that I needed.
Dean
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 10-19-2005, 05:43 AM
randywebb's Avatar
hoop one = older stock hard line that goes under the trans.
I think Bill V. has posted pics of it before if you search.
There are also steel flex lines you can use (over the top) - and pics of those have been posted also.
Old 10-19-2005, 10:01 AM
304065's Avatar
Where does the line hit? I am using a 1971 stock crossover line and it clears fine, about to update to the 1974- line and wondering whether there will be interference when I get the heat exchangers off.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 02-07-2008, 07:52 AM
logician's Avatar
The interference is specific to the '70/'71 gearbox. I believe it's OK with a 915 gearbox supplied in '72 and later. I don't remember any more details than what I wrote originally: "I had started to fit a '74 line -- the hard line that goes under the engine. But that one interferes with the clutch cable termination that is flush with the face of the bell housing."
-Juan
Old 02-07-2008, 07:50 PM
AutoBahned
RWebb's Avatar
Scott Clark recently faced this problem - IIRC, he had fittings made up by Chuck Moreland (Elephant Racing) and then got some hose in town. The whole thing was very spendy.
You can also get a hose with metal braid.
Old 02-07-2008, 09:15 PM
304065's Avatar
Yes, there is a thread by Scott, he and I have been talking about the issue.
The trouble with using -AN hose is I don't know whether the fitting will clear the heat exchanger. The hose Chuck made has very low profile fittings and may be the way to go.
FWIW nobody uses SS braid hoses anymore, most all the teams use ICORE kevlar.
'81 R65
Old 02-08-2008, 02:37 AM
