Arching across coil terminals
Question, yesterday when I was putting my 80 SC back together (frequency valve, and wiring issues) I started the car up and it ran well, not great but just ok. I was about to adjust the timing however I placed my hand NEAR the coil and I received a violent shock!
I waited until nightfall as another post suggested and looked for arching, I in fact have blue sparks on both of the positive and negative coil posts, across the boot. It's actually a pretty loud snapping noise as a result. So is this what happens when the coil fails? Or is it just a coil wire, in either case I have to order one or the other from our host, I just hate to keep throwing parts at this thing.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
bad coil wire, bad plug connector causing the spark to take the path of least resistance (one of the coil terminals is grounded), dirt/moisture on the coil tower, could be a cracked coil snout, or internal corrosion in the snout too. and check the cap and rotor for cracks or burning.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 10-23-2005 at 11:09 AM.. |
Ok, just checked. Coil wire is fried, the metal piece at the end is cracked and tarnished, as are the other plug wires as well for #5 and #3. Coil looks intact after removal, snout does not sppear to be cracked at all. Thank's for the advice on the "path of least resistance" I know nothing when it comes to electrical. I will pop over to the catalog section and order up some new wires. Thanks.
also the word is arcing
if you search on arching you won't find relevant posts check the female terminal on the coil carefully - stick an LED down there if you need to.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab Last edited by Scott R; 10-23-2005 at 02:57 PM.. |
