Boge struts
How do I know if I have Boge struts? I took a wheel off the other day and cleaned the grime off to reveal green Bilstein's. The struts are black. Should there be a marking somewhere?
Reverend Ray
84 Carrera Coupe "DAS-V2"
GruppeB #2119
Volvo V70SE-Wife mobile
Nissan Frontier-Home Depot mobile
Old 10-22-2005, 11:51 AM
Seeeu911's Avatar
Its a terrible pic but here is the general idea. Black Strut housing with a Green insert typically. Once you clean the strut it should have identifying marks like this.
"And there's no cure like travel
to help you unravel
the worries of living today.
when the poor brain is cracking
there's nothing like packing
a suitcase ..(or getting in the Porsche) and sailing away " Cole Porter, anything Goes"
Old 10-22-2005, 01:43 PM
Jeff Alton's Avatar
The bilstein strut has a small roll pin that secures the strut. It is located just above the balljoing wedge bolt near the botton of the strut. It is the only strut that has it.
Cheers
www.turn3autosport.com
Old 10-22-2005, 01:58 PM
Okay, after I degreased the strut it turned out to be green not black. So I guess I have bilstein struts and shocks. Should be less expensive to replace the shock inserts now correct? I think I identified the roll pin also.
Reverend Ray
GruppeB #2119
Old 10-23-2005, 09:09 AM
Jeff Alton's Avatar
I do have a pair of sport inserts for sale in the classiffieds right now, 3 months old, about half the price of a new pair.....
Cheers
Old 10-23-2005, 09:12 AM
Catca - I'll check'm out. Why you sellin?
Reverend Ray
GruppeB #2119
Old 10-23-2005, 09:14 AM
Jeff Alton's Avatar
I have coilovers and went to a revalved unit when I changed spring rates.
Cheers
Old 10-23-2005, 11:05 AM
