SWB to LWB conversion questions?
I have a 68 shell. I know I need lwb quarters and trailing arms to start the conversion. Do I need to swap out the rear axle cross tube and the cross member(where the shocks bolt to) for 69 or later ones, or will the 68's work properly with the longer arms?
Thanks Shelby Pruden Memphis, TN |
Shelby
I've done this on my '66. You will need to replace rear quarters, trailing arms, spring plates and the torsion tube. The only reason I did it is because the PO had the rear quarters done already and then gave up. Replacing the torsion tube is not fun. The spring-plate inner bushings on the SWB and LWB have different ID and OD so you'll have to work your way around that.. You will also have to reroute the rear brake lines and replace the emergency brake cables. As far as I know the cross member is the same. It is not worth doing it IMO. Others on this board have told me this several times and in hindsight (always 20/20) I should have just cut out the LWB rear quarters and replace them with SWB quarters. Martijn
'66 3.2 "Blue Car" '73 3.0 "Orange Car" '78 3.2 "Brown Car" |
A '68, even with a reasonable restoration, would be worth more in original condition. Replacing the torsion bar tube is THE most major surgery you can do to a 911. Front and rear track are different between SWB and LWB.
Unless the '68 is a complete basket case you might look around for a LWB donor car-- it will be a LOT cheaper and faster in the short term.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Thanks for the info guys.
I plan on picking up pieces for it slowly here and there as they come up for sale cheaply here and on ebay. I also plan on bending and welding an IROC roll bar for it. It just seems wrong to let it die, however I will not spend too much to get it usable. I have 3.0rs track car ideas for it. Worse case scenario: I sell it off or tube frame it. Shelby
Once Upon a Time: 1980 911 SC Sunroof Coupe, 76 Turbo Tail, Bilstein Sports, Ruf-type bumpers, SSI's, Sport muffler, Wevo engine & Trans Mounts, OMP Corsica wheel, Momo hub Last edited by shelbypruden; 06-24-2008 at 09:59 PM.. |
Thread Tools | |
Rate This Thread | |
