Tune up cost on 3.2
PLugs, wires, cap, what do these usually run ??
2012 XC90- wifey 2011 BMW 535I -Daily Driver 911/964 Widebody Cabriolet-Protosport Stage 1.5 Turbo |
Friend of Warren
If you are doing it yourself you can look up the prices right here on Pelican.
Kurt V No more Porsches, but a revolving number of motorcycles. |
These are off the top of my head here but should be pretty close:
Plugs (6): $24.00 Dist. Cap.: $50.00 Rotor: $18 Air Filter: $$16.00 Fuel Filter: $26.00 Oil Filter: $8.00 Valve Cover Gasket kit: $20.00 Oil (case): $26.00 Wires: Pricing can vary by manufacturer. $140.00 - $285.00
The Fox Carrera |
Wider is Better
Pelican sells a kit for $135, without wires.
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_BASkit_pg1.htm#item4
Wider is Better |
