Still more problems - CIS?
Well I am at wits end, and I am really just trying to get my SC into storage at this point, but here is the deal:
Replaced- Injectors and seals (had a bent injector of all things) Air boot between throttle body and sensor plate Intake boots Intake runner gaskets Cold start valve (was inop) Timing/frequency valve (caught fire) WUR (no change in cold control pressure when hooked up) Coil wire (had a crack in the metal anode at the coil side) Cap and rotor So now I have a new issue, I suppose... When I start the car it's hard to start, you have to crank it a while, then it backfires a bit through the air box and then catches. It runs after this, clean and smooth as the idle stays up over 1000k for about three or for min, then the idle drops. It drops to around 950 and starts to miss-fire through out the range, I shut it down and wait about 5 min then it starts up strong again and then drops and misses. I really want to try and figure this out, I spent a combined $700 now on three mechanics that can't get a handle on this, seems like CIS is getting rare and so are the experts.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
regap your points and look for an air leak
X/A |
what are the various CIS pressures? looks like someone measured the cold control press. what was it, and the ambient temp?
poof! gone |
CIS Trouble Shooting......
Scott,
Trouble shooting CIS problems could be both frustrating and expensive if you don't know how to check these compoments, WUR, AAV, AAR, FP, injectors, CSV. TTS, etc. But I find the most challenging is locating a vacuum leak in a CIS system. This system is reliable and will last for a long long time if properly maintained. Tony |
ditto with yellowbird..check points..old or dirty ones will cause backfiring. also, check timing..make sure that this is set correctly. in other words, baseline your ignition by starting with ignition basics: points set correctly, timing set correctly..then start looking for air leaks if still experiencing problems by spraying a little carb cleaner around the intake and airbox areas. good luck!
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
Ok, well this is just great, I lost my notebook with my pressures, however I remember that cold control was 35 or so PSI and warm was 53 IIRC.
Now I went out to the grage and I have tremendous arcing between the coil posts, in fact I have a continous ZAP between the two terminals, and little blips of spark all over the braided grounds! Has the coil failed? My multimeter stopped working the other day so I can't yet check resistance on the coil, but why would it do this? EDIT: It's an 80 so no points, I wish at did at this point, (no pun intended) Also on the airbox leaks it was removed and checked a few weeks ago, it appeared sound on all sides.
Banned
i guess you learn somthing new everyday
Scott, I'll take a crack.
You say that the car is hard to start. Is this a cold or warm start condition or both? Approximately how many secs of cranking does it take to start and what is the ambient temperature? Have you measured the warm and cold control pressures and system pressures? What were they and what was the temp they were measured at? What is the part # on your WUR? After replacing all this gear, have you had the mixture checked on an EGA, or tried playing with it? You describe a couple of problems that to me would point to different causes. The hard cold start is usually unrelated to poor cold running; a poor warm start can also have different causes. The fact that the car runs OK upon finally initially starting but then drops after a bit leads me to believe that the WUR is still not operating correctly, as enrichment from the WUR would be responsible for ensuring a smooth transition from the cold to warm regimes. Any change if the O2 sensor is disconnected? Do you have a popoff valve and is it seating properly on its gasket? ianc
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 |
Both cold and warm are hard starts, about 60 seconds of cranking on cold, it catches right away on warm but dies until you hold the gas for a while Quote:
If you have an adjustable WUR, then you should be able to set your control pressures very accurately if you have a pressure gauge and know what temp your checking at. The ambient temp is very important. Let me know your pressures and temp and I'll look them up in the factory workshop manual to see if you're in spec. Making sure control pressures are in spec is the absolute first step in diagnosing a problem like this. ianc
Will do on the pressures, and it's cold starts crank for sixty seconds then catch, idle is low then idles up and runs well until warm.
Hot starts are about 30~60 seconds cranking and I can't keep it running at all unless I have my foot on the gas. As far as the thermotime wires are concerned I think they only fit one direction, red IIRC is on top and the white is on the bottom.
OK, so it sounds like you're having both cold and hot start problems. Hot starts problems have different causes than cold start. Most likely culprits for hot start are the fuel pump check valve and the fuel accumulator.
Cold start issues are usually the cold start valve. The wires on the thermotime switch can be put on either way. I have an 80 also, and the wires are red\black and yellow. The switch is at the far left of the top of the driver's side chain cover. ianc
Maybe your CDI is bad. I was having issues of my car running very irregular and backfiring until it completely stopped running. Switched to an MSD ignition and this solved my problem.
You know it would not suprise me, I don't appear to have consistant spark when I disconnect a plug wire and watch it. Anyway to test a CDI?
Easiest way is to swap with a known working one.... if you can find someone to lend you one.
I am going to borrow one from my mechanic today, he has a few spares so he says.
Scott,
Reference your remark early in this tread about the arcing between coil posts: This is a symptom of no ground at the coil. You might double check this. Trouble shooting CIS is a real problem when the spark is not reliable. You might find some help with CIS by looking here: <http://members.rennlist.com/jimwms/CIS/CIShome.html>
Jim www.jimsbasementworkshop.com (CIS Primer for the 911) (73 911T (RS look) coupe) (Misc. 911 Parts for Sale) |
Also I brought home a loaner CDI unit tonight, and it was the wrong one, I have a six pin and I brought home a three pin. Anyway here is an update on other things, I went out just now and started it up, it stumbled a bit then picked up right away to about 1500RPM, then as it warmed up over say three minuets the idle droppped down to 950 and then it started to arc and miss again. It does not arc until after the warmup part is done. I will try and borrow a six pin CDI tomorrow, but I am still very stumped, and I had no time to check fuel pressures.
I see you replaced the coil wire. Good, I believe that the rest of your plug wires are shot. If they are arching to the braided sleeve, they are probly cracked. Most likely all the spark thats supposed to go to your plugs is shorting to the braids. Try new wires. Tim
Tim 82 SC 90 C2 Yasowatt |
Ok, plug wires it is. Now do I go with braided? Or not?
