G50 Trany- Synthetic or Conv.
87 Carrera- Should I start using a synthetic or keep using the conventional 75-90. Have 125k miles on her...Have had the car since 92. Just a thought..... THERE IS NO SUBSTUTE!!!
Registered Cruiser
87' Carmine Red Carrera - Keeper 82' Silver SC - Sold 79' Gran Prix White SC - Sold 05' Black C2S - Daily driver I have never really completely understood anything. |
3.4 Bigger is better
Synthetic.......
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
mobil 1 75w-90 works like a charm.
Andy |
I use conv. in my G50. Seems to work fine.
Dean
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
REDLINE 75/90 NS THATS ALL I HAVE TO SAY ON THE MATTER!!
Keith Epperlt 87 slant nose turbo look carrera cabriolet |
durn for'ner
As far as I have heard the Borg Warner set up will benefit more from a synthetic oil - at least as compared to the 915.
Markus Resident Fluffer Carrera '85 |
MBruns for President
mobile one
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Michael Delaney wanna-be
Mobil 75w-90. The best insurance your tranny will ever get!
Aaaahh it's back
Andy |
Friends of Warren
I feel so stupid asking this... But where do u put it? Plz do not laugh but how do you change the oil for the transmission?
As with most trannies there is a goesinta plug and a goesouta plug.
Get under your car and look Dean
On the side (driver/left IIRC) of the tranny is a Hex nut for refilling and one on the bottom to drain. Make SURE you can get the refill nut out BEFORE you drain the oil from the tranny. You don't want to empty the tranny and find out you can't refill it. I used one of those pumps to get the new fluid in the tranny.
Probably should pick up Wayne's book and Bentley manual as well...both VERY useful. Wayne's book(s) is/are great reading whether you are doing anything or not and it's an excellent education on 911s.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
Carbon Emitter
There's a 10mm allen key plug in the bottom of your tranny, and another one about halfway up on the driver's side of the tranny as mentioned above. Don't use a standard allen key, get a key tool that attaches to your ratchet wrench. I just did mine with a home-brew non-pump method:
Pick up 3 quarts of Mobil 1 75w-90 oil at your local Auto Zone in the quart containers with the pointed caps. Get some tubing there that fits on the end. Remove the driver's side rear wheel and run the tubing into the upper plug hole on the tranny (don't forget to replace the drain plug). Squeeze the oil into the trans until it starts dripping out of the upper plug hole (the tranny is full at the bottom of the plug. Mine took almost the entire three quarts. This stuff is really stinky if it gets on your hands...use rubber gloves. Last edited by jkarolyi; 10-21-2005 at 01:56 PM.. |
Don't feel bad, I was sorta thinking the same g'damn thing. I have Waynes book but just havent looked it up yet. I will be starting to do my own oil changes next week, I just ordered a bunch of filters and such from Pelican. I guess i will have to look up how often to change the G50 tranny fluid now. --Bill
87' Red Targa 10' Jeep Wrangler Unlimited 07' Subaru Impreza (lease ended) 02' Mini Cooper S (traded )91' VW G60 Corrado (sold )
Carbon Emitter
Wayne's book focuses on the 915 tranny and doesn't detail the G50 change procedure. Pretty similar process though. I've hear 100K miles is fine for tranny fluid, maybe even more for synthetic.
I would guess that if the PO had the clutch replaced that the fluid was done at that time?
It made a world of difference on my 57000 mile tranny - got to believe that it's better to do it at the 30k mile interval
mobil has been sold to Exon and they have cheapened the product. RED LINE 75/90 NS NOW THAT IS MY FINAL WORD ON THE SUBJECT.
KEITH EPPERLY 87 SLANT NOSE TURBO LOOK CARRERA CABRIOLET |
