One year ago now.... Since.."spark plug smashed..."
Hard to believe but tomorrow will be a full year since the following post..
Spark plug smashed severe..What came likely through/contact? How much damage? Followed by a complete self tear down and OEM original parts rebuild through the fall-winter 04, following Wayne's rebuild book and the advice on this board. With the completion in early spring, with the results as of this date, that the car is running strong, excellent compression. ......with highlights participating in the 2 Parade Laps at Mid-Ohio American LeMans Series in May, and the full usage of the car as a daily driver. Rebuild: All "new" heads polished/valves/valve guides OEM. new chains new tensioners two (extremely hard to find) OEM 2.0E Mahle pistons. One replaced OEM Biral cylinder (also a hard find) All new rings New bearings new seals complete new gasket rebuild kit new rocker new rocker arm RS "O-ring seals" case and cam towers cleaned. Cams timed New points New plugs Oil filter cleaned oil cooler new return tubes and o rings Thanks Wayne and members of this board for your contributions.
1969 911 E Coupe "Little Bull" "Horse" "H." Heart, "G." Gears, and "P" the Porsche |
Heading out on the LeMans parade lap led by both Official pace cars (first time ever on a track)
Designer King
Congratulations on a job well done!
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
congrats!
Any more pics of the 964 widebody?
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
HGP would never tell us where he was. Now, we at least have a clue that he is near Ohio.
![]() Glad everything worked out. I was worried about you.
Re: One year ago now.... Since.."spark plug smashed..."
(Just kidding. Nice job!)
1984 Targa |
Irrationally exuberant
Way to go H.G.P.!
Sure, H.G.P may be a little odd but look around on this board - see anyone who isn't a nut job? ![]() Chris "Nut Job" and proud of it!
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Thankee everyone.
