-   -   socket size to remove factory wheel? (http://forums.pelicanparts.com/porsche-911-technical-forum/248494-socket-size-remove-factory-wheel.html)
JBaez 10-29-2005 09:53 AM
I am trying to remove a wheel of my 86 carrera...anyone have the socket size?
thanks!
pwd72s 10-29-2005 09:58 AM
Going from memory here...in '72 I believe it's 27mm...you might give it a try.
Eric Coffey 10-29-2005 10:23 AM
http://forums.pelicanparts.com/porsche-911-technical-forum/217541-steering-wheel-center-nut-size-sc.html
http://forums.pelicanparts.com/porsche-911-technical-forum/148563-steering-wheel-removal.html
http://forums.pelicanparts.com/porsche-912-technical-forum/92430-steering-wheel-nut.html
http://forums.pelicanparts.com/showthread.php?threadid=52082
http://forums.pelicanparts.com/porsche-911-technical-forum/233950-steering-wheel-nut-size.html
http://forums.pelicanparts.com/porsche-911-technical-forum/146847-what-size-nut.html
http://forums.pelicanparts.com/porsche-911-technical-forum/5995-installing-momo-wheel.html
http://forums.pelicanparts.com/porsche-911-technical-forum/78022-steering-wheel-installation.html
:D :p
svandamme 10-29-2005 12:48 PM
a full set of metric sockets is quite handy , you just try sizes till it fits...
i'm sure it's worth the money if you have a german car...
Wil Ferch 10-29-2005 01:20 PM
As I said in another post...it's right there with a search...
properly, 27 mm....or even 1 1/16"..... will work
27mm= 1.0630"
1 1/16" = 1.0625
Almost no difference....you will have clearance problems, though...probably better to go in with a short socket and an extension..instead of a long socket.
Wil
rick-l 10-29-2005 02:53 PM
Re: socket size to remove factory wheel?
thanks!
Does "a" wheel mean he has more than one? Maybe it is the 4 rubber wheels and he needs a 19mm socket for the lug nuts.
Shaun @ Tru6 10-29-2005 02:57 PM
John, good seeing you the other day, let me know when you'll be back up, we'll do dinner. 27 will do it.
You left just in time, it snowed today. :(
bkreigsr 10-29-2005 03:11 PM
oohhh the steering wheel!
dorschman 10-29-2005 03:22 PM
27 mm was 7 bucks at Lowe's
