Targa, Panamera Turbo
M.D. Holloway's Avatar
Changing Shocks and Struts
I will soon have to change out the factory installed shocks and stuts in my 96 Volvo 850. I am pretty confident I can do it by myself - provided I invest in a spring compressor.
Question - if I buy one for the Volvo, can I use it for my 77 also? Any particular type, brand, feature to look for? Harbor Frieght has one for like $30 - any good for a tool I will use maybe 3 times in the next 10 years?
Michael D. Holloway
https://5thorderindustry.com/
Old 10-30-2005, 06:54 PM
Zeke's Avatar
You don't need a spring compressor that I know of on your '77.
I bought the HF one and I've never used it and I had a 914! (has springs)
Old 10-30-2005, 06:59 PM
MuffinMan's Avatar
I concur with Zeke. Since your '77 has torsion bars instead of coil springs, you won't need a spring compressor for the project.
Rob Fusi
77 911S | 3.6 Varioram | Triad Muffler | B&B 9400 Cooler |WEVO everything | Big Reds | 23/33 | 22/22 sways | Polybronze | RSR shocks/struts | FM10s |
GTC Motorsports
Old 10-30-2005, 07:05 PM
vash's Avatar
cheap ones are scary. i almost broke a friend's face helping him with a VW cab. it was the cheapo one that had two threaded rods, that you crank down slowly to pull these jaws together. the system shifts and twist. a better tool is jawlike and has a hinged end, with only one threaded rod to turn. i now let tire shops do it. most mom and pops places have done it for a six pack of bud.
poof! gone
Old 10-30-2005, 07:08 PM
Sounds like I would be better off hitting NTB or Midas huh?
Michael D. Holloway
Old 10-30-2005, 07:10 PM
randywebb's Avatar
Where in TX do you live? Unless you are way out in the sticks lyou can probably borrow one.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 10-30-2005, 08:13 PM
If there is an Autozone nearby you can borrow one from them. You actually buy it then return it, a great program.
Old 10-31-2005, 01:32 AM
