CIS tuning with the LM-1 and my '80SC
I've had the LM-1 installed in my '80SC for about a week now.
Day 1: Innovate LM-1 and my 1980 911 SC
Since then I fixed a minor vacuum leak and set my CO at warm idle to 3.5 (13.2 AFR) from a previous setting of 4.6. Now at cruise/part throttle the car is running around 13.8-14.2 AFR and at WOT the AFR is around 13.0-13.3.
One thing I've noticed is that it takes a few seconds once at WOT for the AFR to go from 14.0 down to 13.0-13.3.
Soon I'm going to hook up the LM-1 CIS trick and set the AFR at WOT to 12.8. I'm really curious to see how quickly the AFR will change when I trigger WOT (instant vs. a few seconds).
I'm going to try and do some datalogging before and after the CIS trick to see if I can plot any acceleration differences with and without the CIS trick.
Stay tuned,
-Scott
Old 11-02-2005, 04:38 AM
It's that 14.0 on CIS WOT that's sold a lot of Webers. There are WUR's that have an accelerator pump feature..they're an emissions no-no of course, but you're obviously not meeting emissions. Has anyone ever tried a WUR that richens the mixture on low vacuum?
Old 11-02-2005, 07:40 AM
I've been researching the adjustability of warm control pressures. This should lower WOT AFR.
I'm actually getting 13.0-13.3 AFR at WOT with my CIS (without the LM-1 mod). It just takes a second or two to get there. In other words, it's not intantaneous like the Webbers are.
Hopefully the LM-1 trick will make the 12.8 AFR change instantly.
-Scott
Old 11-02-2005, 08:19 AM
KobaltBlau's Avatar
Cool Scott! I will be very curious as well whether the trick improves the response.
Hladun, What CIS vehicles have this type of WUR, or roughly what could one look for?
Andy
Old 11-02-2005, 09:34 AM
Here's where I learned how the WUR really operates;
Let's Connect the WUR Right
Earlier (non emissions) 911's might have had this type of WUR.
Old 11-02-2005, 12:37 PM
