hpmad's Avatar
Shifter problem
Hello,
I have a problem with my gear box, it does not want to get in 5th and reverse (ie, I can not move the shift lever to the right).
all the linkage seems to be OK, and so is the shifter, so it looks like it's in the gearbox... does anyone have any idea what it could be and how to fix it?
thanks, cyrille
Old 11-02-2005, 06:12 AM
MBruns for President
JeremyD's Avatar
Car year and age would be helpful.
Old 11-02-2005, 07:19 AM
pa911's Avatar
I believe he has a 80 sc
Old 11-02-2005, 07:46 AM
JeremyD's Avatar
Or the Kayak?
Old 11-02-2005, 07:48 AM
hpmad's Avatar
car year and model
hello,
yes, you are right :-)
1980 P911 SC Targa 5speed 3L engine stock (except for SS headers)
regards, cyrille
Old 11-02-2005, 08:40 AM
JeremyD's Avatar
Cyrille - have you replaced the shift bushings? That's the first thing I would do - especially with a 915 gearbox. There are many threads that cover this if you do a search.
Old 11-02-2005, 08:49 AM
hpmad's Avatar
quesiton
hello,
where are these bushings located?
regards, cyrille
Old 11-02-2005, 08:53 AM
JeremyD's Avatar
Shift Coupler Bushings - Brass or Nylon ?
http://www.pelicanparts.com/techarticles/911_shifting_improvements/911_shifting_improvements.htm
Old 11-02-2005, 09:03 AM
JeremyD's Avatar
and of course, the WEVO shift coupler...
Old 11-02-2005, 09:04 AM
K9Torro's Avatar
Hi
First thing you should do is remove the center console, then lift up on the rubber boot which covers the shifter and make sure that the shift lever has not spun in the cup, which would cause the tab not to line up to fit over between the ears on the top of the housing, thereby keeping it from going into 5th and R.
If this is not the problem , you can then loosen the two smaller allen head screws on the shifter assembly, looking down you should see four large ones and two smaller ones, by loosening the two smaller ones you will gain more play see if this will allow you to get all six gears.
If neither of the above works then you will have to take the shifter off , take a look at replacing your bushings, clean up your shifter, look at your coupler as well, once this is done you should be set hopefully.
A quick way to determine if it is in your trans is to take off the coupler and simply use your hand and clutch to try all the gears, by moving the trans shift shaft by hand. You will definately be able to test reverse that way.
Todd
Old 11-02-2005, 10:33 AM
emcdan's Avatar
K9Torro said it best
Very first thing remove the consol and shifter boot. Right away you'll see the tabs for 5th and Reverse and how it works. It will probably be very obvious why the shifter is not going behind the tabs. (1)One or both may have gotten bent, (2)check if shift ball cup broke, (3)adjustment screw (large nut) facing to the front of the car loose, (4) lastly check the adjustment screws on the coupler between the seat may have come loose. Probably an easy cure. Good Luck!
Lets us know....curious
Deutsche Fahrzeuge
78' 911SC
03' 325I BMW
03' KTM 450sx
05' S2000 (daughters)
Old 11-02-2005, 12:17 PM
DG624's Avatar
Cyrille, do you have any other shifting symptoms...trouble going into 1st or 2nd...trouble downshifting...gear clashing or trouble getting out of gear? I would be intereted in knowing if you change the coupler and whether it solves your problem.
Old 11-02-2005, 12:55 PM
I suggest doing the easy stuff first (Homer Simpson says his two most favorite letters of the alphabet are E and Z). Wise man.
Remove the sheet metal cover from the rear floor and take a look at the shift coupler. Verify the gearbox shift shaft (into the gearbox) moves along with the shift lever. Any loss of movement means there is wear in the linkage joints (bushings). Enough wear can prevent the shift shaft from moving far enough to select certain gears.
Like the others, I suspect a worn shift lever bushing and possibly the front support bushing for the shift shaft.
The adjustment set screw on the front of the shift housing doesn't affect the left-right range of movement. However, it does affect the amount of preload on the lever movement and thus how freely it moves.
Sherwood
Old 11-02-2005, 04:08 PM
Navaros911's Avatar
Cyrille,
As Sherwood suggests, start with the EZ stuff.
That would be:
1. Pull up the rubber boot from your shift lever and check to see if the tabs are bent (just like emcdan suggests)
2. Adjust the coupler see here how that's done http://www.pelicanparts.com/techarticles/911_shifting_improvements/911_shifting_improvements.htm
That would take hardly any time and a toolset of one screwdriver to open the access panel between the seats and two 13mm wrenches to losen the clamp bolt from the coupler.
If that doesn't do it, prepare to change out the bushings... not expensive and very easy.
Good luck,
Michiel
'94 964 - Celebration 30 Jahre edition
'06 997 - arctic silver with cocoa interior - sold
'77 RoW 911 - black and still sexy - sold and I miss her
'05 Audi A3 Sportback 1.9TDI (not a bad daily driver) - gone
Old 11-02-2005, 04:22 PM
