hmd hmd is offline
16x8 951 fuchs on rear
Will these fits the rear of a 75 911?
If not what would size spacer will be required?
Thanks in advance.
76 Carrera 3.0 (Group Sc)
Old 04-06-2006, 06:14 PM
Dan in Pasadena's Avatar
I have a friend who says they will. No personal experience though
Dan in Pasadena
'76 911S Sahara Beige/Cork
Old 04-06-2006, 06:54 PM
PRO Motorsports
Tyson Schmidt's Avatar
Here's my car with 225/50's on 951 8's in the back and no flares. It is possible.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 04-06-2006, 07:24 PM
hmd hmd is offline
Thanks Tyson,
Just confirming no spacers required?
Old 04-06-2006, 07:27 PM
Todd Simpson's Avatar
Nope...your clearance issues will be at the outer edge so spacers will only make it worse.
You'll need negative camber too.
Old 04-07-2006, 04:55 PM
PRO Motorsports
Yep, what Tod said.
In the above pic, I'm running 2.75 degrees negative in the back, as well as a secret mod to narrow my rear track by 7mm per side.
Without the mods I did, you will need to grind, and/or roll the fender lips, massage them out by rolling an aluminum bat between the tire and fender, and running slightly more than 3 degrees negative camber in back.
You could also have 3mm machined off the rotor hat surface where the wheel meets it.
2004 GT3
Old 04-08-2006, 09:13 PM
