Blaine Sellie's Avatar
O2 sensor plug needed for B&B headers
To all,
I installed my new B&B headers this weekend and ran into a small problem. I drove for about 20 minutes and the exhaust changed pitch and sounded like an obvious leak. I limped home and found that the o2 sensor plug fell out that came with the headers.
What size plug is this and will a hardware store have a stainless steel replacement?
Blaine
1988 Porsche 930 Factory Slantnose
2011 Porsche Panamera Twin Turbo
1974 Porsche 914 2.0 Phoenix Red
1965 Shelby Cobra Replica- 428FE
2007 Mercedes SL55 P30 Package
Old 11-12-2005, 08:59 PM
Senior Member
Screw a standard spark plug into it and forget it! Might put some never sieze on the threads.
Joe A
Old 11-12-2005, 10:03 PM
The hole appeared to be quite a bit larger than a sparkplug. I will double check.
Blaine
Old 11-12-2005, 10:06 PM
I've had this Post-It stuck to my monitor for years (along with 20 others containing Porsche trivia). It says the O2 sensor thread is M18 x 1.5 and that a drain plug from a Toyota truck will fill the void.
Hope this helps,
Sherwood
Old 11-12-2005, 11:03 PM
911pcars,
You are correct. A quick trip down to the parts store and I found a rack with drain plugs. M18 x 1.5 is the ticket.
Thanks,
Blaine
Old 11-13-2005, 12:55 PM
