O2 sensor plug needed for B&B headers
To all,
I installed my new B&B headers this weekend and ran into a small problem. I drove for about 20 minutes and the exhaust changed pitch and sounded like an obvious leak. I limped home and found that the o2 sensor plug fell out that came with the headers. What size plug is this and will a hardware store have a stainless steel replacement? Blaine
1988 Porsche 930 Factory Slantnose 2011 Porsche Panamera Twin Turbo 1974 Porsche 914 2.0 Phoenix Red 1965 Shelby Cobra Replica- 428FE 2007 Mercedes SL55 P30 Package |
Senior Member
Screw a standard spark plug into it and forget it! Might put some never sieze on the threads.
Joe A
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
The hole appeared to be quite a bit larger than a sparkplug. I will double check.
Blaine
I've had this Post-It stuck to my monitor for years (along with 20 others containing Porsche trivia). It says the O2 sensor thread is M18 x 1.5 and that a drain plug from a Toyota truck will fill the void.
Hope this helps, Sherwood |
911pcars,
You are correct. A quick trip down to the parts store and I found a rack with drain plugs. M18 x 1.5 is the ticket. Thanks, Blaine
