Somatic Negative Optimist
Gunter's Avatar
Cool Add to this list of Hard-to die-Fallacies
Some practices/believes that don't seem to die out:
"The car has to come to a full stop before the Odometer can be re-set"
"Disconnect the battery with the engine running to test the alternator"
"Test the CDI by checking for Voltage on the coil with a test light"
If you know of any other ones, post them here.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 11-12-2005, 10:32 AM
Unregistered
sammyg2's Avatar
You have to lower the compression ratio to turbocharge an engine.
Old 11-12-2005, 10:36 AM
Recreational User
porschenut's Avatar
If you shave your chest the hair will grow back thicker.
Old 11-12-2005, 10:48 AM
pwd72s's Avatar
The early 911S isn't good for street driving because it's cams are too peaky.
Original Owner
tsuter's Avatar
Turbo tie rods make a BIG difference.
Muhahahaha!
tsuter
78 911SC Turbo Targa
Thaaaats Right!!
Old 11-12-2005, 10:49 AM
PorscheGuy79's Avatar
The same is true for your...wait is this supposed to be about 911s? crap this is okward...
Matthew
“Sometimes the questions are complicated and the answers are simple.”
Old 11-12-2005, 11:01 AM
A well set up 915 is just as good as a G50.
Old 11-12-2005, 11:11 AM
Alan Cottrill's Avatar
I'll save money by buying a 911 that needs some work and then doing it myself.
big AL
'77 911
Old 11-12-2005, 11:48 AM
rdane's Avatar
Re: Add to this list of Hard-to die-Fallacies
this from the guy who just had to rebuild his odometer
Old 11-12-2005, 11:58 AM
Warren Hall Student
Bobboloo's Avatar
Placing the motor behind the rear axle makes sense.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 11-12-2005, 12:02 PM
Kantry Member
oldE's Avatar
These cars oversteer!
Les
Best
Les
Old 11-12-2005, 12:11 PM
Early_S_Man's Avatar
Porsche Crest
CIS is a cheap & easy FI system to maintain!!!
CIS is easier to maintain than MFI!
... this from guys who have spent thousand$$$ on alphabet-soup CIS parts to repair their systems using the 'Shotgun' method of troubleshooting!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 11-12-2005, 12:12 PM
randywebb's Avatar
Ha - Warren stole my thunder... I'll add one tho:
"CIS is a good system for a sports car"
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 11-12-2005, 01:29 PM
Not Quite Banned
Thomas Owen's Avatar
Said to an admiring crowd "I'll just lean in the window and start her up"...
Thomas Owen
1972 911T
1972 911S
Old 11-12-2005, 01:43 PM
PRO Motorsports
Tyson Schmidt's Avatar
Trickle-down theory.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 11-12-2005, 02:09 PM
audi2.7t's Avatar
"Galvanized tubs don't rust...."
'96 Dodge Viper
'09 Maxima
'05 zx10..(0-100-0 before your turbo even spools!!)
'99 Rottweiler
'08 Cane Corso
Old 11-12-2005, 02:10 PM
Designer King
Paulporsche's Avatar
"The only way to get CIS to work properly is by spending a lot of money and swapping in a lot of new parts in a shotgun approach to solving problems!"
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 11-12-2005, 02:12 PM
Oooh-oooh I have a few
G50's weigh 100lbs more than a 915
930's have too much lag
Why are Porsche parts so much more than a Small block Chevy
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 11-12-2005, 02:39 PM
randywebb's Avatar
"I'll save some weight by putting on RS door panels"
carbon fiber cup holders... I can go on...
Old 11-12-2005, 02:47 PM
Unregistered
sammyg2's Avatar
Carburetors work better than CIS.
CIS is expensive and complicated for everyone, not just for those who don't understand it and try to fix it with the shotgun approach (replace everything until the problem goes away instead of doing a logical systematic diagnosis).
SSIs will get you 20 hp throughout the powerband.
Loud exhaust is better.
$100 per hp increase is a reasonable price to pay.
The big bad oil companies are conspiring to rip us off.
Changing from CIS to EFI is easy and fast.
911s should be drag raced.
Wings on the street are cool.
Installing carrera pressure fed tensioners is actually an upgrade.
dodging cones at 30 mph in a parking lot is really racing.
Old 11-12-2005, 03:31 PM
