sweet97m3's Avatar
Front Wheel Bearing Replacement
Hello all, thanks to members here I diagnosed my front end grumble issue as a bad right front wheel bearing. Have two replacement bearing sets on the way (thought it best to do both sides while I'm at it) but had a couple questions:
Sounds like the procedure isn't brain surgery but any special tips for removing the old ones?
Do I need to grease the new ones before install?
What is the worst thing that can happen if I can't get to this over the next couple of weeks and I drive her a a couple times in the meantime? I don't want a bad bearing to cause another problem to develop! (Unfortunately what little near-term wrenching time I have handly is going towards addressing some issue with my dairly driver BMW 535i)
Hope everyone has a safe and happy Thanksgiving!
1986 911 Cabriolet
1991 BMW 535i
1991 BMW 325iC
2005 Chevy Tahoe Z71
2004 Mercedes C240 4Matic
1989 Ford F-150 (for the dirty work)
2004 New Holland TZ-24DA (kicks real grass!)
Old 11-19-2005, 07:54 AM
Redlineshftr's Avatar
Im also tackling this project today! Any tips would be great!
Mike
Currently Porsche-less
Old 11-19-2005, 08:04 AM
Your new bearings will come without grease, so of course you will have to grease them with a molydenum disulfide or synthetic bearing grease. I use a big set of channel locks to get the bearing cover off. After that, you must take the nut off, pull the wheel, put the bearings in, and replace the nut. The nut is tightened down just enough so that you can move the washer under it by prying it with a screw driver using a bit of pressure. Do a search. You'll find tons of threads.
Marv Evans
'69 911E
Old 11-19-2005, 08:20 AM
THE WORST THING THAT COULD HAPPEN IS THAT YOUR WHEEL COULD FALL OFF.Not as dangerous but costly would be that your race will weld to the spindle therefore costing you a new strut assembly.ask me how Iknow,don't drive,Marty
Old 11-19-2005, 08:30 AM
This should get you started.
It may not be as simple as you thought,,, or it may be. Hammer and punch OR heat and press special tools etc.
front wheel bearing install?
edit: grease the new ones definitely... put a wad of grease in your palm and press the edge of the bearing into it until it pushes out the other side.
Old 11-19-2005, 09:39 AM
You have to decide if you are a hot hub proponent or not. I personally ensured the hubs were hot prior to removal and insertion of the bearings. The only tip I can give that I haven't seen on the thread is you need to be careful when checking the pressure washer for free movement. If you use a small screwdriver to slide the washer back and forth it is real easy to snag the bearing race cage and distort the cage.
Steve F
69 911
71 911
87 Carrera
2004 RAM 1500 4x4 "Hemi"
Old 11-19-2005, 11:40 AM
sweet97m3's Avatar
Thanks to all for your help. If anything it gives me pause to think through this project a bit before I dive in. Not sure I really have the terminology down to even grasp what each part is and how to ensure I don't damage something in the process. I may nust explore having this done at a local shop. Makes the valve adjustment on the Bimmer today sound like an oil change...
1986 911 Cabriolet
1991 BMW 535i
1991 BMW 325iC
Old 11-19-2005, 04:24 PM
Don't let anyone scare you off. It isn't that hard. A little common sense and take your time.
oh.. and if you get stuck an urgent post to this place.
Old 11-20-2005, 12:00 AM
Somatic Negative Optimist
Gunter's Avatar
Do a search on this board but, all would be easier if you get a Bentley Repair Manual: Great descriptions with pictures!
It's best to do the front brakes at the same time meaning: Rotor, calipers, pads if necessary.
If the brakes haven't been done for a while, this is the time.
It's a pretty nice job to do it all and that way your front will be good for a long time.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 11-20-2005, 08:49 AM
Dan in Pasadena's Avatar
Rick, I don 't think anyone is trying to "scare him off". But he admitted he didn't know he had to grease the new wheel bearings before installing and he doesn't feel that confident that he understands the terminology. He should proceed with caution as this is a safety related job. Just my $.02
Dan in Pasadena
'76 911S Sahara Beige/Cork
Old 11-20-2005, 09:51 AM
GIBSON's Avatar
Not trying to hijack this thread but I wanted to throw this out to your guys, I'm ready to be blasted for my idea but this idea but I think it has merit.
Once you've packed the bearing with grease, got the seals installed, you are ready to tighten the nut and check the movement of the washer for proper tightness. All of the good work you've done prior to this can be destroyed if you get this step wrong. Too tight and you burn a bearing, long enough and you'll weld it to the race (I've seen it happen). Too loose and it will wear out the assembly and destroy it as well.
So, lots of experience setting the tightness of the adjusting nut and checking the movement of the washer (not just by me but by guys who have done them many times) has given us an idea.
A properly set bearing will not heat up as it's running the proper adjustment. Too tight and you can actually feel the heat from the cap over the hub assembly.
So, we've determined that 5 thousands is about the right amount of play at the top of the rotor- if you grab the rotor from the vents top and bottom and rock, you should feel some slight movement, this translates to 5 thousands.
So, we made a bracket that attaches firmly to the strut and has a piece that allows firm attachment of a dial indication. It should be within .5 inch of the edge of the rotor.
Once you adjusted the tension on the bearing to allow 5thou of movement of the dial indicator, you good to go. Check the washer and you find it moves with slight sideways pressure. Torque the adjuster down to 10 ft.lbs and bolt the wheel back on. Drive the car and you find the bearing cool and comfortable.
Now, I'll get a lock of flack for this for lots of reasons but it works for me and is very repeatable. I like non-subjective measurements, repeatable and consistant. The pros will laugh at this because they've adjusting wheel bearings for so long they do it in their sleep. I don't and like a method that I can be sure will give me regular results.
Now, it works on 911's through 1989. Obviously on later cars with larger diameter rotors, you've got a different situation.
Flame away, just thought I'd post it.
Photos:
Bruce Herrmann
97 C4S
'04 330i
'08 Cayenne S
'07 4.8 X-5
Old 11-20-2005, 05:01 PM
randywebb's Avatar
so... you don't rotate the rotor -- hence runout is not added to the axial play (?)
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 11-20-2005, 05:04 PM
GIBSON's Avatar
I just check the movement in several positions, it should be similar or you've got some other problems... And, I never take the measurement alone, always check to be sure the movement of the washer is correct, but so far it always has been.
If you think about it, run-out is not a factor in this measurement.
Whatever spot you pick on the rotor is going to allow you to measure the 5 thousands movement you are looking for. Of course this set-up allows for a nice way to check run-out as well.
But for purposes of this measurement, pick any spot on the caliper for the reading, it's going to give you the numbers that will tell you how tight the bearing nut is.
Bruce Herrmann
97 C4S
'04 330i
'08 Cayenne S
'07 4.8 X-5
Old 11-20-2005, 05:08 PM
sweet97m3's Avatar
I have the Bentley for the e34 and have been impressed with the photos and details provided. I don't have a problem following such guides/manuals and consider such "opportunities" as learning points and confidence builders. I've tackled a few things on the Bimmer so far but this project - and yes on my dear 911 - is a bit more sobering. That said I have also never really mucked with a front end beyond routine brake maintenance, the safety issue does concern me as well as causing a problem that could damage the hub. I'm researching this a bit more and may take the plunge on the 911 Bentley version....not just for this project. No offense taken as I really am embarking on serious DIY projects for the first time. I'm just glad I have this board to help me along the way - even if it is a recommendation to have the work done professionally.
1986 911 Cabriolet
1991 BMW 535i
1991 BMW 325iC
Old 11-20-2005, 07:00 PM
the hardest part may be trying to get the dust cap off. What a show stopper if you can't get it off.
1984 911 Euro Cabriolet
1988 928 S4 with Murf Supercharger S1
Old 11-20-2005, 07:24 PM
Send a message via AIM to Flipseat
Don't forget to put in new races especially if you have a cooked bearing. Make sure the races are completely seated also. I pound mine out with a hammer/punch and then pound in new ones with a hammer and appropriate size race driver.
Old 11-20-2005, 07:38 PM
84toy's Avatar
Gibson, your idea is great but your clearance in my opinion is too loose. As you stated, too tight will burn up but your .005 at the rotor translates to a bunch at the tire not to mention the wobble of the rotor will push the calipers pistons in and give you a softer brake feel. Most performance applications require less than .002 of total rotor runout and you just added another .005. Just my opinion though, I run zero clearance.
When I really see problems is when someone beats the races out with a punch, damaging the seat and the new races go in slightly cocked. Then people tighten up the bearing excessively to get the play out because of the misalignment problem. If the races are installed properly, you can tighten the nut with two fingers and get all the play out. Zero clearance will not burn up the bearings if the races are installed straight.
Paul S
"Those who say it cannot be done should not interrupt the people doing it"
Old 11-20-2005, 07:41 PM
Gibson That is excellent!! I'm getting out the MIG welder right now (hold my breath for the zinc on the screw).
We had one vote for too much clearance. Your empirical method seems pretty sound. Any one else weigh in?
Old 11-20-2005, 09:42 PM
GIBSON's Avatar
Paul, I understand your concerns. My reason for starting this project was that bearings I thought were adjusted correctly using the standard method were producing heat beyond which I thought was appropriate. This was not caliper/brake pad heat showing up on the rotor, but heat from the bearing housing.
Not being one who like subjective measurements (I use a dial gauge on my valve adjustments as well, eliminating the "feel" portion of the adjustment). So, this is an attempt on my part to produce more reliable, reproduceable results. I understand your concern on the "looseness" of the bearing. I have found, however, that this measurement gives a washer that responds
to lateral pressure as it should. I used to think that the proper way to adjust these washers was to lever the screwdriver against the bearing housing and try to slide the washer to see if it was tight enough. When I learned that the movement of the washer was to be just by the action of the screwdriver against the washer and just pressure from your hand (not levered against anything) I realized I was setting things too tight.
I know this is a radical approach - don't try it unless you think it will improve your chances of getting an even, proper torque on the wheel bearing. If you feel that 5 thou is too loose, use 3-4 but from my experience, I've had good results with 5.
Just an idea, if you like your current adjustment method, stay with it. I just think it's a good idea to check for heat in this bearing assembly after you've installed new bearings or repacked you old ones.
You could probably use the magnetic stand with flexible arm to mount the dial indicator but I felt that the rigid frame would give more predictable results.
Another trick most of you probably already know, leave the allen head wrench in the nut for the adjuster to make your small adjustments for tightness- you can just turn the rotor slightly the appropriate direction, it will tap on the allen wrench and rotate the adjusting nut in whatever direction you need. Easier than tapping on the nut with a screwdriver and hammer to rotate it.
Bruce Herrmann
97 C4S
'04 330i
'08 Cayenne S
'07 4.8 X-5
Old 11-21-2005, 11:49 AM
sweet97m3's Avatar
Ordered the Bentley
Thanks once again to all that threw their $.02 in. I've order the Bentley manual and will review the replacement procedure and decide which way to go. I really want to take a shot at this and most comments and related threads have been encouraging! Certainly it has got to be better than holiday shopping!! I'll be sure and holler for help here if indeed I need it. Hope all had a nice Thanksgiving.
1986 911 Cabriolet
1991 BMW 535i
1991 BMW 325iC
Old 11-26-2005, 05:57 AM
