Premium vs Regular per Daimler Chrysler
-This is copied STRAIGHT from AllData program, no modifications whatsoever.
Quote: NO: 14-08-97 GROUP: Fuel DATE: Nov. 21, 1997 SUBJECT: Poor Driveability With High DI (Driveability Index) Fuel MODELS: 1996 - 1998 (AB) Ram Van/Wagon 1996 - 1998 (AN) Dakota 1996 - 1998 (BR/BE) Ram Truck 1998 (DN) Durango 1996 - 1998 (FJ) Sebring/Avenger/Talon 1996 - 1998 (JA) Cirrus/Stratus/Breeze 1996 - 1998 (JX) Sebring Convertible 1996 - 1998 (LH) Concorde/Intrepid/LHS/New Yorker/Vision 1996 - 1998 (NS) Town & Country/Caravan/Voyager 1996 - 1998 (PL) Neon 1997 (PR) Prowler 1996 - 1998 (SR) Viper Roadster/Coupe 1997 - 1998 (TJ) Wrangler 1996 - 1998 (XJ) Cherokee 1995 - 1998 (ZJ) Grand Cherokee SYMPTOM/CONDITION: Long cold start times, warm-up sags, hesitations, and driveway die outs. These symptoms are most noticeable and severe at moderate ambient temperatures between 4 - 27 degrees C (40 - 80 degrees F). DISCUSSION: Gasoline with a high Driveability Index (DI) can cause the above described symptoms. DI is a measure of the gasolines total volatility, or tendency to vaporize completely. A high DI number is less volatile than a low DI number. Most premium gasoline sold in the U.S. has a higher (worse) DI index than regular or mid-grade gasoline. Use of premium gasoline is NOT recommended for vehicles designed to run on 87 (R+M)/2 regular or 89 (R+M)/2 midgrade gasoline. High DI gasolines also cause higher emissions for the same reasons they cause driveability problems. For vehicles that require an octane rating of 91 (R+M)/2, premium is recommended, or possibly required. Using premium fuel with a higher than recommended octane rating is not recommended. Owners who experience fuel related cold start and warm up driveability problems should try a gasoline with the recommended octane rating or different brands of gasoline until they find one that provides good performance. The octane quality of gasoline is only a measure of its resistance to spark knock. The use of higher than recommended octane gasoline under normal operating conditions does NOT improve startability, idle quality, fuel economy, driveability, acceleration, engine durability, or emissions. In fact, most higher octane gasolines available in the U.S. have higher DI values than regular gasoline. Customers are most likely to experience poor driveability with premium gasoline than with regular. Some vehicles, such as Viper, Prowler, 5.9L Grand Cherokee, 2.0L Turbo Talon, and 2.0L DOHC Neon have been specifically designed to take advantage of higher octane. These vehicles may have higher compression ratios, and/or more aggressive spark calibrations which provide optimum performance with the specified higher octane. However, other vehicles which are not specifically designed and calibrated to take advantage of higher octane will not benefit from higher octane. Some vehicles may experience light spark knock in situations such as trailer towing or climbing steep sustained grades. Light knock or "ping" under these conditions is not harmful. However, if the customer is concerned about light knock under these circumstances, the use of 89 (R+M)/2 or even 91 (R+M)/2 premium gasoline may be temporarily warranted. If a vehicle is experiencing heavy spark knock on gasoline with its designed octane rating, this may be an indication of excessive combustion chamber deposits, or some other problem. Combustion chamber deposits can be removed with Mopar Combustion Chamber Conditioner p/n 04318001. Standard diagnostic procedures may help in identifying other potential causes of excessive knock. Some gasoline marketers may advertise that their premium gasoline contains extra detergent additives. Under provisions of the Clean Air Act, ALL gasoline sold in the U.S. must contain effective deposit control additives. Nevertheless, if fuel injector or intake valve deposits are suspected of contributing to poor performance, occasional use of Mopar Fuel Injector Clean Up p/n 04549613 is a much less expensive way to maintain engine cleanliness than regular use of premium gasoline. -I just thought it would be interesting to show you guys since a lot of people have argued which fuel is best. -BaTmAn http://www.dodgeintrepid.net/forums/showthread.php?t=61363 Last edited by stlrj; 11-20-2005 at 10:46 AM.. |
Makes sense to me. Hmmmm, I wonder if the MOPAR injector cleaner works as well as Techron? Maybe it is techron?
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
EXACTLY the SAME PROBLEMS were noted ... and SAME RECOMMENDATIONS were made ... when the low-compression 2.4 engines came out for the '72 models!!!
Times don't seem to have changed much in that regard ... in the past 34 YEARS!!! Use regular ... if that is what the mfr says! There was no such thing as DI in the fall of 1971, yet, but the volatility and difficulty igniting the fuel/air charge was the specific issue addressed in C, M, A [the Blue Book] and factory bulletins!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' Last edited by Early_S_Man; 11-20-2005 at 12:35 PM.. |
It also seems that many of the driveablilty issues reported on this board might be due to the unusually high proprtion of uninformed but well intentioned people using premium in their 911's because they chose to ignore what the manual says. Joe Last edited by stlrj; 11-20-2005 at 03:17 PM.. |
