Mike, that is actually what this thread is for.
Coil was originally black with a brown top, larger diameter than what you have there. while were are on the subject aluminum console board is semigloss black with silver cad plated clips That is a non-original ballast resistor, no longer needed with the "blue" coil because the coil is designed to run all the time at +12v. The earlier coils were basically +9V for normal operation and the ballast resistor relay cut the resistor out of the circuit to increase the voltage (which was lower anyway because the starter was cranking). I don't recognize the fuel pump, the base is a hardi but the pump is different. There should be a piece of tape around the base of the voltage regulator. About an afternoon's work if you wanted to put it back to "concours" but if it runs fine, drive the hell out of it! Thanks for posting.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
1968 2.0s
![]() I see the Hardi pumps come up fore sale every now and then, can I presume the same pump was used for Ts Ls and Ss Mike.
1968 Super. 1959 Super. http://tinyurl.com/pbvfl5w Will this learning curve ever level out ? |
Hardi pump
Mike, I have a "Hardi" pump from my '68 I am not going to use. $50 and I'll ship it to you.
Matt ![]()
Matt Cooley 1974 911 |
1968 2.0s
![]() You have a PM. Regards, Mike
Coil Sticker on '67 SWB 911
304065-
Here is an image of the original Bosch paper sticker on the coil of an early '67 911 coupe. Finishes: Top: Brown Coil Body:Satin Black Coil Bracket: Silver Zinc ![]()
flunder |
Ignition Console
Here are the before and after shots
flunder |
![]() ![]() ![]() ![]() See rubber standoffs for fuel pump. ![]()
"farking Porsche hero"
John, are there supposed to be washers on both ends of the rubber standoffs under the fuel pump or are the ends of the rubber pieces flared? I can't tell from the picture. The rubber standoffs on my car don't have washers or flared ends and the fuel pump is pretty bouncy.
Thanks for this thread!
Rich '66 911 #303872 '07 Cayman '17 Macan '58 Land Rover S2 88" |
Never mind, I figured it out. The washers are embedded in the standoffs and no matter much you dare tighten the pump down, it's still bouncy.
Newbie needs help
![]() I want to clean up my engine's electrical system and replace some worn out components as well. My ignition system looks similar to "Mycar's" (post #40) but mine looks like its missing some additional parts. Attached is a picture of my current setup, if anyone can provide any insight as to what I'm missing and what the numbered components are (especially part #5, what should it be connected to?) in the diagram, I would greatly appreciate it. Thanks! ![]() |
First of all I assume your car is a 68 from the ballast resistor and the three point mount for a hardi fuel pump.
1- noise filter capacitor to meet VDE radio noise rules 2- ballast resistor, 68 type 3- ballast resistor relay 4- Bosch "blue" coil- early type aftermarket coil form 1970s. 5- plug connector for voltage regulator Missing- Hardi Fuel Pump on the vibration isolation studs Missing- voltage regulator Missing- wiring for ballast resistor Missing- center fin for terminal block (under the coil center electrode) Hope this helps
Is it working like that .
Hello All,
I just want to know if we can remove the starting relay and the ballast resostor like that ? This should be simpler as possible like that. ![]() Rgds Freddy |
Thread Tools | |
Rate This Thread | |
Tags |
john cramer rebuild |
