Capping one side of a B&B muffler
Hey,
I am going to install a B&B muffler (and headers) this weekend. I'm wondering if I can cap off the passenger side. There are two reasons for this: 1. Hopefully it will reduce or eliminate resonation 2. I don't want to cut or remove my rear valence if I can avoid it. So will this damage the engine? I don't really care about maxing out performance. I'm taking baby steps, so I can always open it later and change the valence. I'm just trying to be minimally invasive to the car at this point. So does B&B have their exhaust gasses mix, or is it separate compartments for each side? Will half my cylinders be like Rosewood's car with a banana in the tailpipe? Opinions and thoughts are appreciated.
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
abit off center
Yes you can, the 2 outlet is the same as the single, at least it is on my b&b, mine was a single which I changed to dual
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Thanks Craig. That corresponds to the view I heard earlier - that on the more recent B&B systems (this is about a year old) they reduced the size of the passenger-side outlet to reduce resonance. If they can reduce it without a noticeable drop in performance, you can cap it, or so the theory goes.
I was speaking to Steve Timmins at instant g, and he was a little more hesitant. He felt that there was some benefit in the gases being allowed to mix (I guess this answers part of my question from before) and said I probably shouldn't cap it, but he wasn't very adamant. Just looking for some more clarity. Has anyone done this?
1-888-228-7435
Not trying to be rude, but Call B&B. there sales reps are normally very helpful and knowledgable. They can tell you for sure. No guesses go to the source. |
Green Skull 006
I capped the right side on mine to eliminate the resonance between 2-3k rpm. I talked to B&B about the problem and they suggested the modification and said that they didn't notice any difference on their dyno in either configuration.
S Reg 823 R Gruppe 246 1955 pre-A Carrera Speedster...x 1974 leichtbau..."Sascha" "It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a PCA Parade concours field. |
