It has been done and seems to work. But it is a pretty small area to weld without interfering with the friction surface. I think the loctite or JB weld methods are easier.
If you do weld, you still need the shims.
Chuck Moreland - elephantracing.com - vonnen.com |
I mig'd mine after shimming it-it took some care, and just a couple small welds. Fine after 5k. You do need to be very careful an use low heat.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
