I have recently purchased my first Porsche, a 1983 911SC Cab. I am easily troubled by noises that I do not recognize or do not know why they occur. While decelerating down a hill, and using engine compression for braking, I hear a popping, or backfiring, out of the exhaust. What normally causes this noise and/or is it normal.
Thank you for response to this possibly stupid question........But, I will feel better once I know what this is. |
Retired Member
it is running lean. Need to richen the mixture.
1982 911 SC Targa - Rosie....my Mistress. Rosewood Metallic on Dark Brown and Black. Long distance road warrior and canyon carver. A few mods - a little interior, some brakes, most suspension and all of the engine. |
Don't worry about it too much, most older Porsches do it. It's when it's backfiring through the intake that you need to worry.
Check out the above suggestion.
Matt J. 69 911T Targa - "Stinky" 2001 Boxster "Stahlgewehr" |
Detached Member
Not a pcar expert, but actually, isn't it running rich? Above the upper explosive limit and the mixture leans out in the exhaust and detonated/lights off as it leans into the explosive range as it enters the exhaust system?
Hugh |
Air Medal or two
also could be a hole in exhaust upstream.......usually will never be cause for concern (the back fire) if not to obnoxious.
Is it a stock P sys. on it ??
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
I have copies of the service records back to when the car was 8 years old, and there is no record of replacing any portion of the Heat Exchangors or Exhaust. I think that the care is pretty much original. I have been looking at a SSI & sports muffler system?
Thanks for the replys! |
RETIRED
Hole in the exhaust or leak in the flanges...
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Metal Guru
My SC is set rich and I've heard the popping (a backfire is a much more extreme event) ever since I gutted my muffler.
Many race cars do the same thing. I don't think it's a big deal.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
Senior Member
It sounds like a lean condition. Where? Who knows, could be a vacuum leak, hose off, gasket on the intake manifold or many other things.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Unregistered
Lean causes backfires through the intake, rich through the exhaust.
Check or replace all exhaust gaskets, then have the mixture checked. |
RETIRED
Run the motor, wet your hands and pass it over the bottom of the engine feeling for a leak.....best to do so while car is on a rack....or take it to a muff shop.
Irrationally exuberant
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Registered abUser
popita-pop-popop softly is normal and I like it! You might have an exhaust leak or be running a little rich. I probably have both. Better too rich than too lean. Do you have a working catalytic converter?
KAAPOOWW!! Is bad and can blow off exhaust hardware. |
Isn't deacceleration poping a result of the CIS not having a fuel cut-off when closing the throttle?
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Cause: Too much fuel on overrun (exhaust leak and/or gutted muffler will amplify it)
Thank you for your time, |
Driver
The beauty of the internet. Guy asks a seemingly simple question, and gets 3 or 4 different responses--2 of them totally opposite. FWIW, I vote for too rich. My 930 does it, too. I love it, as it makes the car sound all snarly and mean. And minor popping on decel is not supposed to be harmful.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
I just added a Fabspeed cat-bypass and Fabspeed muffler last week, installed by John Walker.
I get a slight burbling and small popping on deceleration, sounds great and healthy. However if i am going really slow or stoped and I rev it up a few times it will POP on the deceleration portion and it sounds to a regular person like an out of tune car. I am guessing this is normal and there is unspent fuel igniting in the cat area that now you can hear clearly. I am going in for a new O2 sensor in a couple of weeks and will have John check for any leaks. I dont see any when i start the car in the morning. I have not ordered my SW chip yet, would the re-mapping help in excess fuel burn-off?
87' Red Targa 10' Jeep Wrangler Unlimited 07' Subaru Impreza (lease ended) 02' Mini Cooper S (traded ![]() 91' VW G60 Corrado (sold ![]() |
Popping on deceleration, if not from intake or exhaust leaks, is usually caused by a lean part throttle condition just prior to letting off the gas pedal. Removing exhaust restrictions such as by removing the cat, and installing premufflers and sport mufflers create the lean condition. The lean mixture has a difficult time igniting in combustion chamber, so the unburnt fuel goes out into the exhaust manifolds. On the next cycle, the same condition repeats, and eventually enough raw fuel accumulates in the exhaust to ignite, and thus the backfiring and popping. Remapping additional fuel in the lower rpm part throttle range typically alleviates the condition.
For example, if one were to evaluate the factory mapping for the European spec 911s, which have the lower restriction premuffler exhaust, and don't have the exhaust popping, you can see Porsche did the same thing to the fuel curves. |
Air Medal or two
Yup
Thread Tools | |
Rate This Thread | |
